the best place is next to the compressor outlet
that way you take out any loss from the pipework, intercooler core and other junk along the way
if you look at pics of the HKS 2835 ProS youll see the actuator gets a signal from its own compressor cover, this is the ideal way
but most common places are intercooler pipe work before the intercooler is fine
https://www.sau.com.au/forums/topic/222989-boost-reading/#findComment-3928896
this is 100% right unless you have a turbo with a large compressor wheel and very small housing. an example would be a bax oversize rb20 turbo. there is to much turbulance and pulsing to get a steady pressure.
in this case you are best off getting your feed 10 to 20 cm away from the compressor housing. I have found the profcb and other solenoid ebc's do not cope well with turbulant boost scources. this is due to the sample rate they use and their limited processing ability.
cheers :thumbsup:
https://www.sau.com.au/forums/topic/222989-boost-reading/#findComment-3929689
CEF11E and Paulr33..... i don't mean to take nything away for you guys as ur right in your application
BUT i believe airbornesoldier is talking about a line for a BOOST GAUGE...the usual place for a mechanical gauge is to just tee into the stock like which comes out from the back of the plenum (my old r32 did anyway).
unless im missin something here i think u guys are talking about the boost line from turbo to actuator to control wastegate...this is entirely different to boost pressure reading line for gauge and i thought i've read here that that actuator line should never be used as a boost reading.
a) because it'll add a bit of overboost
b) if somethin goes wrong at gauge side of things you've very possibly got infinate boost!
https://www.sau.com.au/forums/topic/222989-boost-reading/#findComment-3931315
This is the way i plumbed it on my r33. Teed it off the vacum hose coming out of the plenum (where the stock boost guage gets its reading i believe). Stock Guage and Aftermarket digital guage both work nicely.
I think the main thing is to make sure its after the FMIC, otherwise your reading the boost the turbo is making rather than the boost at the engine.
https://www.sau.com.au/forums/topic/222989-boost-reading/#findComment-3931504
i d go along with what WAN73D & Housie are saying. I also T'd off a nipple at the back half of the plenum (R32 RB25DE+t).
I think I'll put individual nipples for BOV, boost gauge, wastegate actuator feeds, now I have the plenum out for fwd facing plenum mod - it was getting too messy with T off another T etc.
At the same time I'm putting a spare boost gauge at the compressor housing, just to be sure of what boost the turbo is making before all the pipework - I hear 25DET turbo is good for 12 psi ish at turbo and wanna make sure it's below that at turbo.
https://www.sau.com.au/forums/topic/222989-boost-reading/#findComment-3931656
  • 1 year later...
I just got my boost signal right of the stock line, pulled that one out and put it straight to my boost gauge, its at the end of the plenum. And my boost controller signal is connected to my fuel regulator line.
https://www.sau.com.au/forums/topic/222989-boost-reading/#findComment-4992780
    • @joshuaho96 Hmm considering the drama you've seen/experienced, have you looked into getting a built complete long motor shipped from Australia?  Considering the AUD is basically monopoly money when compared to the USD, at a glance this seems like a good option?
    • Bloody Skylines, they put you through the bloody wringer! Stick at it! Stunning drag strip BTW! Where is it? Can see part of the name on the slip and probably should just Google it!
    • I mean the other day I had to walk someone through diagnosing why their timing belt was walking off the cam gears. At least one of the issues was a bent tensioner stud. Local mechanics have found runout on the CAS mechanism causing weird failures. I'm also no saint here I've documented some of the things I've had to learn the hard way. Something I discovered recently is that my CA emissions catalytic converters weren't even welded correctly to align the downpipe to the main cat and they tossed the support bracket that goes from the transfer case to the downpipe to support everything there. I spend a lot of time chasing down these decidedly unsexy problems and the net effect is it feels like I never actually get to the original objective (flex fuel, VCAM, oil control, cooling, etc).
    • At times with how you make everything sound, all I imagine Americans doing when they see a gtr is standing there looking at it and bashing it with a gun like how a caveman would with a club and hoping it fixes itself
    • I think this is just a product of how the US market works for this stuff. Shops are expensive and there's no real way of knowing what kind of results you're going to get, people don't really have the institutional knowledge. I have heard too much at this point to really put faith in anybody "full service" except maybe DSport and they aren't really a full service kind of shop. If you go to the right place I have no doubt they'll get it right for you. Some locals have set it up right but the cost really is nuts and even now they're still fighting issues. And you know I'm a crazy person who thinks things like twin scroll, relatively short low-mount cast headers, PCV recirc to intake, recirculating BOV, right-sized for ~400 whp, MAF load, validating all of that to a standard comparable to OEM test programs, etc are relevant. For what it's worth, multiple local owners at this point have been stuck in a perpetual cycle of blowing a motor -> getting someone to rebuild it -> some missed detail causes the bearings to wipe and spin just outside of break-in mileage or drop valves or some other catastrophe -> cycle repeats. I usually only find out about this because I'm perpetually helping random friends with diagnosing car troubles, Skyline or otherwise. The single turbo stuff if I'm honest is mostly secondary, it just doesn't seem to achieve the numbers in the ~2000-3000 rpm region that I would expect given the results I've seen here or in Motive's videos. I don't really know what we're missing here in the US to be causing this. Lots of people like to emphasize the necessity of finishing the project first and foremost, but I'm not made of money and I can't afford to be trashing a 15k+ USD engine build with any regularity. Or spending my relatively limited garage time these days unable to triangulate problems because too much was changed all at once. Also, even if it isn't a catastrophic failure I would consider spending the cost of single turbo conversion with nothing to show for it to be pretty bad.
