Got the head back last week. It better go as good as it looks.
It's had 13hrs worth of porting done, valve seating, head plained, new heavy duty valve springs and cam followers.
The cams are new 280° to match the intakes.
We just have to setup the cams in the head and it's ready to go on for the test fitting of the itb's.
Hopefully the fabrication of these will be done in the next week or two.
The ports have had a lot of work done on them to change the size and entry angle of the port to the valves, should make a good difference there.
This week I have to sus out an ECU to run the thing.
  • 1 month later...
oh man..
oh baby..
that so farkin hot!
Could I ask a rough price for the project?
Could you write up how much better the responce is? how much and where in the rev range the improvements where?
Edited by GTS4WD
Dunno Rach, just kinda doing it on the side. At the moment I'm waiting for some alloy tube to turn up for the runners, then it's a matter of getting it all tigged up.
Think I'm going to run a Link G3 with a tps and map.
You think thats hot, wait till I've got the trumpets on it, mmmmm. :D
Cost so far... NZ$300 for itb's and NZ$2,900 for the head and cam work (mates rates!)
My mate is doing the CNC machining, so I'll see if I can buy him out with beer. :D
Hey mate,
Nice work. Looking good.
I recently built an RB30DE using 25DE head from an R32 with a modified RB26 6 throttle inlet to fit. Throttle response is unbelievable! I find myself rolling off the power just so I can nail it again. Havent go mine fully tuned yet... Only tuned to 4000rpm. It currently makes 86kW at wheels at 3000rpm (10BTDC and a little rich) so I cant wait to unleash it!
Yours should be somthing along these lines too!! What compression did you end up with?
Again mate, awesome work!!
Cheers for the comments guys. I want to have it going for next season, so that's Novemberish.
Hopefully it sounds good, only 2ltrs though so hopefully I don't have to rev the rse off it to get the benifit out of the itb's.
SR20's sound like rse, I thought the world of rallying could do with the sweet RB sound :P (SR would be better for weight distribution)
Nosmo, what ecu and sensors are you running? I'm not sure of the compression, it's on a bit of paper somewhere. Kelfords were instructed to set the head up for the highest possible compression I can run on 98 octane. MSNZ is outlawing Avgas at the mo.
Edited by screamin'
ECU time...
What are your guys thoughts and experiances with Microtech LT12s ECU's?
A performance shop has recomended this to me and the price seems very fair, as long as it does what I want it to.
I need to read a Toyota TPS, aftermarket MAP sensor and do all the fuel and spark as per stanadard RB20.
http://www.microtechefi.com/microtech-prod...hp?product_id=5
Cool. Sounds like the LT12s comes with the MAP sensor going by what the supplier tells me, which will save me a few dollars. He's quoted NZ$1,650. Way cheaper that what I've been looking at previously.
That's why I'm a little bit sceptical.
    • Has equal chance of cleaning an AFM and f**king an AFM. I think you can work out what happened. When the Hitachi ECU sees the AFM die and goes into the associated limp mode, then it will start and run just fine, because it ignores the AFM and just runs on idle maps that will do what it needs to get it going. But there is no proper load signal, so that's about all it can do. My suggestion? If you don't want to go full aftermaket ECU, then get some R35 GTR AFM cards and some housings to put them in, in the stock location, and Nistune the ECU. Better to do a good upgrade than just replace shitty 40 year old tech with the same 40 year old tech.
    • So my car was recently having trouble starting on initial crank, I would need to feather the gas for it to start up but besides that it would start and run fine. So I clicked the idle air control valve (with throttle body cleaner) and cleaned the MAF sensors (with MAF cleaner). The start up issue was fixed and now the car turns over without the assist of the throttle, but the car is in limp mode and wont rev past 2.5k RPM. From what I understand the IACV would not put the car in limp mode, so I am to believe it is the MAF sensors, but it was running fine before and now I cant get it out of limp mode. I cleaned the MAF made sure the o rings were seated properly. Made sure the cables were plugged in properly, the cables also both read the same voltage. Does anybody know why this is or what could be causing this or how to get it out of limp mode?
    • Ooo I might actually come and bring the kids, however will leave the shit box home and take the daily
    • Thanks. Yeah I realised that there's no way I'd be able to cover the holes with the filler, it would just fall through. Thanks again @GTSBoy!
    • That was the reason I asked. If you were going to be fully bodge spec, then that type of filler is the extreme bodge way to fill a large gap. But seeing as you're going to use glass sheet, I would only use that fibre reinforced filler if there are places that need a "bit more" after you've finished laying in the sheet. Which, ideally, you wouldn't. You might use a blob of it underneath the sheet, if you need to provide some support from under to keep the level of your sheet repair up as high as it needs to be, to minimise the amount of filler you need on top. Even though you're going bodge spec here, using glass instead of metal, the same rules apply wrt not having half inch deep filler on the top of the repair. Thick filler always ends up shitting the bed earlier than thin filler.
