It really comes down to who is tuning the car. Make sure your tuner is comfortable and very familiar with the ECU.
Personally I like the Autronic. As good as a Motec, but without the huge price tag and 'pay more for more features' bullshit. Autronic has everything available from the get-go.
Will the Microtech work with Nissan sensors, CAS, etc?
Like I said, 'Plug and play' lol........ just needs a vac/boost line from after the throttle body.
the thing about the individual throttles and the map sensor is that you need a vac line from after each throttle that then goes into one line.......
thats my understanding anyway (at least to get a good stable reading - you could grab it off one, then use a multiplication factor or something, but it never would be as right as a line from after each throttle)
if you havent yet, have a gander at this site
http://v8soarer.com/itb/index.shtml
guy did ITB's for his v8 soarer............
Yip, Toyota has the same on their itb's. I'll be running a vac line from each one for the MAP.
For the brake vacuum boost I'm going to fit a diesel Navara alternator. They run a small compressor off the back of them for the brake booster. :dry:
Interesting project, keen to see how it turns out. Certainly an unorthodox approach, especially given the car's purpose in life, but I wager you're a better judge of that than some bloke across the tasman on a computer!
  SKYPER said:
Triple 2 barrel side draught setup on a S20 motor -
http://www.datsunhistory.com/skylineeng.jpg
Thats an L-series six old mate, only one cam there!
Edited by floody
Personally i would be steering clear of the Microtech. I ran an earlier LT8 on my old RB20, ok not an LT12 and they were a bit crude in the fuelling dept. They were also very sensitive to voltage, which is still a common problem based on some cars i see running the LT12.
After a lot of time and effort tuning i was finally able to get some reasonable control of fuel, and on an NA car you want the fuelling spot on to give you that sharp throttle response.
I know it wil partly kill the sound, but have you considered a big fibreglass airbox for the inelt setup? Filtration will be easier to sort, an important thing for rally car. You can also throw a an AFM on the front of it after the air filter panel. I have seen similar setups on several 80s rally cars running injection. It also means you can run the std ecy re-mapped to your needs.
I love what you are doing, every time i service for a friend i sit in the bush listening to all the cars coming through and dream of building a basic NA RB20 GTSt rally car. The sound of the RB20 through the bush would be awesome.... :)
Its a bit late..
But my old man just pick up a 26 intake manifold for his 25det. I been looking.. could custom trumpets just be slapped up to ITB's on a 26 manifold?
Because then you can mate to the head.. TPS is sorted.. etc
Edited by GTS4WD
26 intake with the 4age throttles? Could work. Mate of mine works in the CNC machining industry, so I've just given him another homer to do.
We're going to dummy up some runners next week and see what we can make fit.
a guy i know has fabricated plates to adapt the RB26 throttle bodies onto the RB25 head... let me know if you are keen and i can put you in touch with him. actually i think he has a thread floating around here somewhere
Hmm, got a small problem with the itb's. The Toyota factory spacing is too different to the head ports on the RB. I was just going to take up the difference by using the intake runners to line them up but now we've got it in bits I don't have enough length to do so.
So now the linkages between the itb's need to be modified and a new flange made to suit. No biggy, we'll get there...
Here's a pic of the smelly old head and ports. Will be good to see a nice shiney head in it's place.
  • 4 weeks later...
Also...
5 out of 6 fit!
Link ECU will be here in a day or two and the car is getting shipped back to the workshop where we can start:
Building the head
Re-plumb the coolant lines from the head.
Re-plumb the clutch master cylinder (that's why #6 don't fit)
Remove HICAS servo thingy
Wire in Toyota TPS
Plumb in MAP sensor
Move battery
Make new throttle cable
radiator
fan...
Oh god that's getting depressing!
Looking awesome mate!!
Roy: Microtechs were our ecu of choice, when wired up properly we rarely had any dramas with them, they have come along way in recent times, and for sheer bang for your buck i dont believe you can go past them for a full stand alone ecu once people get there head around the fact that not being plug and play for all applications isnt such a big deal. Customer service on the otherhand could do with some improvement.
Now that the ITB's are built and the dummy fitment has been carried out, we can get stuck in and remove all the stuff we no longer need, to make way for what we want.
Flicked out the radiator and took the stock head off the other afternoon.
Now we can look into all the plumbing adjustments and flick some paint on the red bits.
My G4 Link ECU has turned up now too, so most of the bits I need to make it run are here.
  • 3 weeks later...
Yeah we're getting there slowly. We're all too busy to spend much time on it.
The engine bay has been cleaned and painted, I've re-plumbed the powersteering and removed the redundant HICAS pipes also.
I've prepped the block and should be fitting the head this week.
    • From there, it is really just test and assemble. Plug the adapter cables from the unit into the back of the screen, then the other side to the car harness. Don't forget all the other plugs too! Run the cables behind the unit and screw it back into place (4 screws) and you should now have 3 cables to run from the top screen to the android unit. I ran them along the DS of the other AV units in the gap between their backets and the console, and used some corrugated tubing on the sharp edges of the bracket so the wires were safe. Plug the centre console and lower screen in temporarily and turn the car to ACC, the AV should fire up as normal. Hold the back button for 3 sec and Android should appear on the top screen. You need to set the input to Aux for audio (more on that later). I put the unit under the AC duct in the centre console, with the wifi antenna on top of the AC duct near the shifter, the bluetooth antenna on the AC duct under the centre console The GPS unit on top of the DS to AC duct; they all seem to work OK there are are out of the way. Neat cable routing is a pain. For the drive recorder I mounted it near the rear view mirror and run the cable in the headlining, across the a pillar and then down the inside of the a pillar seal to the DS lower dash. From there it goes across and to one USB input for the unit. The second USB input is attached to the ECUtec OBD dongle and the 3rd goes to the USB bulkhead connected I added in the centre console. This is how the centre console looks "tidied" up Note I didn't install the provided speaker, didn't use the 2.5mm IPod in line or the piggyback loom for the Ipod or change any DIP switches; they seem to only be required if you need to use the Ipod input rather than the AUX input. That's it, install done, I'll follow up with a separate post on how the unit works, but in summary it retains all factory functions and inputs (so I still use my phone to the car for calls), reverse still works like factory etc.
    • Place the new daughterboard in the case and mount it using the 3 small black rivets provided, and reconnect the 3 factory ribbon cables to the new board Then, use the 3 piggyback cables from the daughterboard into the factory board on top (there are stand offs in the case to keep them apart. and remember to reconnect the antenna and rear cover fan wires. 1 screw to hold the motherboard in place. Before closing the case, make a hole in the sticker covering a hole in the case and run the cable for the android unit into the plug there. The video forgot this step, so did I, so will you probably. Then redo the 4 screws on back, 2 each top and bottom, 3 each side and put the 2 brackets back on.....all ready to go and not that tricky really.
    • Onto the android unit. You need to remove the top screen because there is a daughterboard to put inside the case. Each side vent pops out from clips; start at the bottom and carefully remove upwards (use a trim remover tool to avoid breaking anything). Then the lower screen and controls come out, 4 screws, a couple of clips (including 3 flimsy ones at the top) and 3 plugs on the rear. Then the upper screen, 4 screws and a bunch of plugs and she is out. From there, remove the mounting brackets (2 screws each), 4 screws on the rear, 2 screws top and bottom and 3 screws holding in the small plates on each side. When you remove the back cover (tight fit), watch out for the power cable for the fan, I removed it so I could put the back aside. The mainboard is held in by 1 screw in the middle, 1 aerial at the top and 3 ribbon cables. If you've ever done any laptop stuff the ribbon cables are OK to work with, just pop up the retainer and they slide out. If you are not familiar just grab a 12 year old from an iphone factory, they will know how it works The case should now look like this:
    • Switching the console was tricky. First there were 6 screws to remove, and also the little adapter loom and its screws had to come out. Also don't forget to remove the 2 screws holding the central locking receiver. Then there are 4 clips on either side....these were very tight in this case and needed careful persuading with a long flat screw driver....some force required but not enough to break them...this was probably the fiddliest part of the whole job. In my case I needed both the wiring loom and the central locking receiver module to swap across to the new one. That was it for the console, so "assembly is the reverse of disassembly"
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
