I did search and went through forum to find the best alarm immobiliser for my R34 GTT.
Finally, I want to install M80G recommended by Daniel but unfortunately, he's on honeymoon holiday until 30 June.
Who else can install good stuff for me because I'll get my car on road on tuesday 10 june?
Please advice, much appreciated for your answer.
Thanks,
https://www.sau.com.au/forums/topic/222998-anyone-can-install-m80g-in-sydney/
I would personally wait for your trusted installer to come back (put a German Sheppard next to the car and Sniper on the roof across the road from it until you get the system installed).
I can do it, but you dont know who I am, you dont know my quality or attension to detail, and you dont know if I am dodgey enough to try and make a back door entry for later...
Get it done by your trusted guy :D
B.
I recently got a gtt and did similar research and found out Autowatch is the best alarm/immobiliser on the market. I got mine done by Leon from Security in Motion .. he's in Sydney, give him a ring if you want. $450 or so I believe for the alarm/immob.
Thanks again for all comments, Unfortunately, I can't wait for Daniel because car has to be parked on the road. I have installed M80G by Nick (Electrician guy who is recommended by Mongoose company) his shop is in Randwick. btw, just found some problem with the glass breaking sensor which sound sentitively when it's raining on my sunloop. Finally, it's fixed by decreasing volumn sensor so it's then working fine now.
    • Yeah, really happy with how it all turned out As for aftermarket lip, nah, I'm not really a fan for practically reasons on a street car that gets driven everywhere  I did have the full lower kit on my 2015 STI, but found the front lip scrapped alot, even at stock 4x4ish ride height As the NC sits now, with the lowest point of the car at 110mm, so just legal, some steep driveways and steep speed humps will still "just" scrap those little plastic OEM air dam thingies on the undertray just before the front wheels
    • Here's one I help build and tuned a decade ago, Garrett  GTX3071R Gen 1, T3 twin scroll 0.83 rear housing. Went from larger 272 cams down to smaller Tomei Poncams to help with the low end. S13 non VCT motor. Car was purpose built for the track, hence low down was the focus. Note the actual dyno chart shows lower boost, however the EBC and boost gauge showed 1.9Bar (Ignore the torque, I was young and didn't know how to set derived torque)
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
    • Awesome writeup and details. Thanks for sharing the story so far. I can relate to parts of it with my previous car and some of the issues I had to deal with.
    • Wow the colour matched hard top completely transforms the car. Are there any nice front lip options for the car or is that off the table?
