Garage Cleanout - Arc 27mm/25mm Swaybars, Hks & Turbosmart Bovs, Brembo/r33/r34 Brakes, R33 5 Stud Hubs, Boost Controller, Seats, Freebies
Selling the follow parts all located in Adelaide but will post at buyers expense. Contact me via SMS on 0404998591 or PM me
SWAYBARS
Brand New ARC 25mm Rear Hollow Swaybar complete with D Bushes to suit most Nissan Imports e.g. S13/180SX/Cefiro/R32 etc. Has S15 on the label but they are all the same according to wreckers and have compared it to S13, S14, R33 stock swaybars and is the same. $200 FIRM (Paid $300)
Front 27mm Front Swaybar complete with D Bushes to suit S14/S15 unsure of brand came off off S14 may fit other cars - $150
Or both the above for $300
Also have the following stock bars for $20 each
R33 Front & Rear
S13 Rear
S15 Rear
BOVs
HKS Sequential BOV complete with hotpipe to suit R33/R32 (RB25/RB20) but could be cut/modified for other cars. Price - $110
Turbosmart Type 2 Vee Port BOV this is the modern version not the old blue/orange version often seen. Price - $110
Brakes & Hubs etc
R33 Front Calipers complete with lines, pads, clips, shims, pins etc - Price $280
R34 Rear Calipers, Rotors, Pads, lines, Clips, Pins etc - Price $260
R33 Brake Booster + Master Cylinder (Non ABS) - Price $100
R33 Front Hubs, Uprights etc - Price $200
EOI on the following as will keep either depending so pm me with offers for either R34 Brakes or 350Z Brembos
R34 Front Calipers and Rotors complete with as new pads
350Z Track Edition Brembo Brakes both Front & Rear complete with rotors, pads etc these are the same size etc as R34GTR Brakes
JUN BL Muffler - this is the rare model like Marky used to run with the angle cut tip with JUN BL embossed into the side of the tip complete with ~60cm of pipe and flange! Cost $600 new used for the last 11 months sell for $250 If anyone is interested in buying this to suit R33 can supply complete exhaust for extra
GAB 8 Stage Damper Adjustable Shocks complete with lowered springs ready to bolt into your car. Shocks are in excellent condition, have been fully dissembled and checked, absolutely no leaks or knocks and can be adjusted from stock stiffness to rock hard in seconds. Perfect for those who want more control over there handling at the click of a dial. These will fit R33/S14/S15 although were removed from R33. Price $125
Boost Controller - electronically activated boost controller valve allowing you to run stock boost and then at the flick of a switch run the boost level you set on the valve. Needs a switch as the one I used for this is still mounted on my console and too difficult too remove again :DPrice - $35
Z32 AFM Plugs + ~30cm of loom ready to splice or wire into your loom to run Z32 AFM. Come complete with instructions on wiring into SR, CA & RB Powered Vehicles
Price - $30 Delivered or $20 pickup
Pair of R33 Front Seats in excellent condition. The drivers seat has a small tear in bolster nothing major. This is the comfy plush velour type model with the adjustable side bolster wings for more support through corners etc.
Price - $150
Freebies
Pair R33 Front Castor Rod Chassis Mounts
Pair S13 Rear 4 Stud Hubs
Location - Adelaide
Contact - SMS 0404998591 or PM
Pics of all bits will be up tommorow
As posts can't be edited after 2hrs updated post with pics is below
SWAYBARS
Have the following stock bars for $20 each
R33 Front & Rear
S13 Rear
S15 Rear
BOVs
Brakes & Hubs etc
R34 Front Calipers and Rotors complete with as new pads CURRENTLY ON MY CAR SO NO PICS ATM
Brand New R33/R34 Front Cusco Camber Adjustable Upper Arms have just been trial fitted but never driven on as have changed plans on car so now up for sale - Price $450
Boost Controller - electronically activated boost controller valve allowing you to run stock boost and then at the flick of a switch run the boost level you set on the valve. Needs a switch as the one I used for this is still mounted on my console and too difficult too remove again :banana:Price - $35
Z32 AFM Plugs + ~30cm of loom ready to splice or wire into your loom to run Z32 AFM in excellent condition. Come complete with instructions on wiring into SR, CA & RB Powered Vehicles
Price - $150
Freebies
Edited by nigelswazi
