  • Replies 57
17's are standard on R34s, so 18" is definitely no problems. FYI you will have a tyre placard sticker in your drivers side door-well for next time (if you don't have one Regency will fail you purely on this fact).
https://www.sau.com.au/forums/topic/223083-defected/page/2/#findComment-3930345
im lost aswell lol track is adjusting the hub, i always thought the width of the rim wouldnt metter its only when you change the hub(s13 coilover conversion to a r31)
Can someone help me because im very lost
i think what they are trying to say is that with wider rims, it increases the width from outside to tire to outside of opposite tire. i think?
https://www.sau.com.au/forums/topic/223083-defected/page/2/#findComment-3930449
that sucks dude, but like everyone has said just return the car back to stock form other then the fmic and pod.
tyer placard would be on the car somewhere and you should have showed him, besides, cops have books with all that info init. should have told him to get off his ass and look it up.
DONT try and pass with a PFC computer, not worth the hassle and your car will be fine running the standard ecu.
coilover will deffently NOT pass. dont use aftermarket sus at all as they will be very picking on it and if they dont know much about the brand they will ask you to change to stock.
also, even though your rims are legal. i never take the chance for them to do me for some load rate reason or something stupid like that. stockies are always the best bet or a set of 17's that arent as wide.
marky at ET can do a rental exhaust system for you or spot weld a silencer and remove it after for a small fee if your not to confident on DB limit.
i always like to take no chances with regency though so its up to you, im realy fussy about it.
might see you at regency dude, im defected aswell :) and sorry for the noval haha
https://www.sau.com.au/forums/topic/223083-defected/page/2/#findComment-3930601
didnt they recently update the rim inch so u can have whatever size you want aslong as its not sticking outside the guard.
i swear i read something somewhere. need to go searching
doesnt sound right. people would be going around with 22ichx8 wheels everywhere. ?
anyone know bout the front strut brace ? should be ok.
will the car have to be re tuned etc if I rip the powerFC out. Is it a straight swap ?
https://www.sau.com.au/forums/topic/223083-defected/page/2/#findComment-3930606
i think he means only width wise, still the same 2 inch rule for height
https://www.sau.com.au/forums/topic/223083-defected/page/2/#findComment-3930610
The PFC will hold the tune, it's written to the ROM on the board... just switch them over and then switch them back... not a drama :)
nice.
howmuch for a standard ECU. ? should be too much? would be cool to borrow one somewhere, but if they are cheap enough might as well get one for future dramas/.
https://www.sau.com.au/forums/topic/223083-defected/page/2/#findComment-3930658
yipee gotta love defects lol
and yeh doin the dodge wont work,
tried it before and it was in a commy so yeh not good haha
but get all stock parts and you might make it through first time
and try to book monday morning or friday arvo (they will be at there laziest then lol)
https://www.sau.com.au/forums/topic/223083-defected/page/2/#findComment-3931654
    • I also built one, for a bit of a laugh. Pretty happy with it. Basically, obtained a clear garnish, painted it sanded back the paint off the letters, clear coated it. Inserted a 3cm EL strip through a slot I created in one end and sealed it up.
    • Apexi SAFC - AFC 1st Generation Rare Old School JDM As you can see it all lights up in the photos and is in 100% working condition. Has been kept in storage and boxed for years there won’t be to many like this if any! Especially with all original packaging and manual. price:$650   APEXi SAFC 2  In Complete Working Condition Refer To Photos and view the video provided.  Price:$500   Located Melbourne - Australia Wide Postage Available At Buyers Expense  IMG_6981.mov
    • wow so i just logged back in after buying the 33 and joining SAU, And I've got all a whole bunch of you wanting to know more, well unfortunately it still doesn't run i was hoping it was seized from a snapped timing belt as i turned it over by hand and it was fine and then it did a few revolutions and jammed solid when i was running it with the key, so the timing belt is mint, I've also found a lot of the parts I'm removing have already got bolts undone or not quiet tight enough to be unsuspicious. so the plan is to find a running RB30 block and chuck my head on it.  I have a habit of buying stuff I don't need or require so for my none running engine i have a forward facing plenum , Apexi power fc, 40mm Turbosmart wastegate, And for the car its self coilovers ,low seat rails and BRZ seats (black seats with red stitching i already had these and they are ADR Approved and allow rear passengers access)
    • I took apart the dash and found this strange 2 pin connector. it dosen't seem like its factory or oem, any clue on why someone would add it and where it might have been connected too?
    • Not mention a SS2 especially with that rear oddly small rear housing. I feel the Facebook mechanics and experts has led OP in the wrong direction.
