Items:
HKS FILTER with adapter for rb25det/
Malpassi fuel regulator/
FET Turbo Timer + Greedy one Both with plugin looms for R33 s2/
Nolethane Front Castor Rod Bush Set R33 s2/
Fermal Flex Turbo intake pipe + intercooler etc 3" size/
Custom Cusco Coil Pack Cover suit s2 R33/
Standard turbo intake pipe for rb25det turbo/
hks?
malpassi reg brand new with guage aswell
fet turbo time ? on car when i bought it
greedy turbo timer 6months old
castor rod bush set brand new just opened plstic thats all to have a look
fermal flex brand new
coil pack cover brand new
stand intake pipe good condition no cracks etc.
Condition:
Everything works fine can post more pics if you like but all the stuff is in good condition.
Price:
hks Filter: $50
malpassi regulator with guage : $130
Fet turbo timer with plug in loom : $50
Greedy Turbo Timer with plug in loom : $60
Nolethane Castor rod bush set suit s2 R33 : $60
Fermal Flex Pipe : $30
Cusco coil Pack Cover : $145
Standard rb25det turbo intake pipe : $40
To Fit:
(What car)some RB's R33's R34's etc
Adelaide South Australia
Contact:
you can contact me here or call me on 0401409575(Allan)
Comments:
i need to sell these item's asap all in good condition will post at buyers expense fell free to ask question etc hope to hear from yas
cheers
Allan
Edited by R334door(s2)
https://www.sau.com.au/forums/topic/223088-random-stuff-for-sale/
  • Replies 66
I have also got a ARC blow off valve too don't know what vehicle its for so i can let it go for $50 will take a picture soon.
with the greedy turbo timer its still in my car can remove and take pic's anytime just not now too cold out side lol.
And with the coil pack cover it is polished.
here's the picture off the ARC blow off valve plum back :
i think you will have to get a adapter made up or something.
with the Castor rod bushes i got where from outlaws speed shop in Adelaide i cant remember what brand it is but it is good quality still got mine in the car and they work great.
Bump.
pm sent
pm replied
Custom Cusco Coil Pack Cover : SOLD Pending Payment.(Till Friday)
link to Greedy Turbo Timer Manual -------> "Click me to download Greedy Turbo Timer Manual"
here is the picture of the greedy turbo timer it is abit dusty because off being tucked under the dash.
Greedy Turbo Timer Sold(pending Payment).
does any one know why i cant edit my 1st post its like the edit button went walk abouts after about 2hrs.?????
Bump
i offer $100 for cusco coil pack cover
no thanks $100 is too low
coil pack cover back up for sale person that was interested did not call or get back to me so its up for grabs
so ill do it for $130 pickup OR $145 delivered anywhere in Australia.
can yous please contact me on my mobile as my internet is down at the moment had to goto a friends place to check and update.
my number is
0401409575(Allan)
cheers
Allan
how long is the peice of thermal flex???
About as long as the keyboard on the computer not certain as my tape measure is at my sisters ill find out after for you if you like.
cheers
Allan
most off the items are still available guys "n" girls except for the.
Greedy Turbo Timer which is sold.
bump
    • Absolute Legend 🍻 After fighting with the scanned ones for the last 10 years this is a God send
    • ATTAKD 356mm Brake Kit for R34 GTT or R33 GTST. Same brake kit as per here from JJ: https://justjap.com/products/attkd-brake-kit-nissan-skyline-r34-99-02?currency=AUD Can confirm these will bolt directly to a R33 GTST with 12mm bolts OR to a R34 GTT (which is what I had) with the supplied bolts and the collets for the 14mm bolt holes in the R34, which are included. Also included is a set of rotors and hats, as well as 2x brake pad sets. 1) DBA XP (street, hills) 2) Forza FR6 (track) These are radial mounted and bolt directly to R33/R34. You will need extended brake lines to avoid them being full stretch on lock - this is common for all BBK's with the bolt point being in the center. In my case I welded another stud about 25mm lower than the OEM one and retained stock lines and fittings. You'll want a BM57 BMC to get the most out of these. I speak from experience. $1800 (neg for SAU people), located SE Suburbs Melbourne.
    • Set of R33 GTST Calipers, Rotors and Pads. Calipers just taken off my car, rebuilt about ~30,000km ago. Rotors have done about ~20,000km total since new. Pads have plenty of meat. One set is DBA XP (road, hills) and the other set is Forza FR6 (track) Still working perfectly, not rusted, or seized or whatever the hell that greets used brakes. All clips, bolts, retainers, slide pins etc included. Also have OEM handbrake shoes I can throw in there if you're doing a conversion. $650 for the lot, SE Suburbs Melboune/VIC
    • I feel I have covid right now. I spent the time between Dec 21 and Jan 31 pretty much working 16 hour days on the car after it got back from paint. It turns out you generate a long list of "things to do" while the car is off the road but functional. After going to visit my mate for a "Couple of hour job" doing the brakes, 3 full days later I got home There was more on the list, (it got added to while sleeping on couches) but as everything on the list got enthusiastically crossed out as it happened, I've actually forgotten what they were. From memory there were bushes that had to be pressed in and out, washer jets to fit, etc. Some Gregging highlights: 1) The panel shop covered up my washer jets and painted over it. Good job, I think. We had to drill the new bonnet to fit new ones, which was understandably extremely scary. 2) My handbrake on the RHS is f**ked. After never adjusting it forever and learning on the fly, this one is still on my to-do list. It tightens when you pull the lever, but at about 10% of the tension that the passenger side does. Thoughts on what causes this would be great. 3) Pouring an entire liter of brake fluid over the reservoir because I forgot how to use my pressure bleeder. DON'T PUT FLUID IN THE RESERVOIR. IT WORKS BY USING PRESSURIZED AIR NOT PRESSURIZED FLUID.   471907729_9242915229093447_2708910336906717367_n.mp4  I can confirm the vents work great though. 4) Some of the bodykit fixings were f**king awful. I'm talking screwed in with what was at most a 2mm screw, and could flap the kit around by hand. Too many others to mention. They came in, went out of my brain forced by other stupid tiny things that came up and "While the car is on the damn hoist we can fix them" which was a mission in and of itself, because the car has skirts and is thus a pain to put on hoists. Because we had to buff the windscreen to get rid of the overspray, I also had to very gently wash the car. The "Run 3 wires" task was to re-attempt another gregging thing which was: The LS1 ECU in Australia does not have oil pressure wiring because the Commodores do not have a 'real' oil pressure switch The Corvettes in the USA do have oil pressure wiring because Corvettes have a real oil pressure switch. The ECU is the same physical ECU. So what I could do is pull the ECU apart, run 3 more pins and run it to the OEM oil pressure ECU, and the ECU should do this. What actually happened is that Greg did this with some not-so-proper-wiring/connectors to the ECU pins which 'might?' be okay put the car back together, and then the fuel pump wouldn't prime. So you can imagine I immediately undid all this work, put the ECU back into it's original configuration, thought I'd do some more research about what connectors the LS1 Ecu actually uses... and try again later. Except still no fuel pump prime. After a lot of sadness and checking/double checking it turns out it was the relay in the boot that controls the fuel pump. All I did was switch the trigger wires and it worked fine. I looked at the relay and it was covered in bog dust and was unknown years old. It's since been replaced and working fine. After I got the actual connectors, and the wires were ran I gathered my strength and repinned the ECU and Voila! I apologize for these MMS  472164532_8829400773820369_5410969472548349643_n.mp4  And even via ODB2 on the headunit, woo. Now Torque Pro can raise hell on track if it gets too low. It has a wonderful EMERGENCY_DISTRESS_SINGAL style warning if it goes below a certain threshhold. 472585876_9345134268844369_146554337148747327_n.mp4 TLDR: Car great. HFM kit works. So much cleaning. Buy my old stuff. Thanks.
    • That's a hell of a question right there and so broad that you could get 100 different answers and have them all be correct.  To avoid me typing up a 2000 word thesis that doesn't answer your question, do you have specific things you are unsure of? Does the car currently handle in a way that you don't like? Or is it closer to, you think the car drives fine currently. But you'd like it to be better, but you don't know what that 'better' is or what that 'better' feels like?
