hey guys
i was just wondering if someone could tell me if the plates 8005TD or BOO5TD are allready taken... as i am stuffed for ideas and i just happen to pull this one out of my arse after reading high performance imports lol...
thanks for your help
https://www.sau.com.au/forums/topic/223093-custom-plates/
go to www.dpi.wa.gov.au
click on licensing services
and then custom plates
then call the contact number
and ask if its available
they will tell you that you cant substitute numbers as letters - so dont say 'i want boosted with a 5 as the S' just say it letter / number at a time
clearly people have words written with letters, but the ppl on the phone are a slightly retarded
https://www.sau.com.au/forums/topic/223093-custom-plates/#findComment-3934637
In hind sight you could have saved yourself a lot typing and just posted the phone number to call :blush:
[CUSTMPL8] :thumbsup: . You could probably sell them for $5000 like [GTHO P3] or [TORANA] or [bROCK05] :D
Edited by Topaz
https://www.sau.com.au/forums/topic/223093-custom-plates/#findComment-3942482
In hind sight you could have saved yourself a lot typing and just posted the phone number to call :O
[CUSTMPL8] :domokun: . You could probably sell them for $5000 like [GTHO P3] or [TORANA] or [bROCK05] :O
but i couldnt be bothered to open a new webpage :O
https://www.sau.com.au/forums/topic/223093-custom-plates/#findComment-3943519
Thanks for all your help guys....
i did end up ringing and they are available so all i have to do now is go down and finalise them by putting a payment down...
so ill probly get BOOSTD... which i think will go well with my going to be worked 25
the 25 is getting put into my 32 as we speak :)
https://www.sau.com.au/forums/topic/223093-custom-plates/#findComment-3943587
hey guys....
nah i doubt im the wellzy their talking about... be gwd if if they were haha
wat are they saying about this other so called wellzy and wat the hell is DORI DORI
lets just say that welzy aint the most popular person,
and dori means drift in japanese
https://www.sau.com.au/forums/topic/223093-custom-plates/#findComment-3944641
sorry to semi thread hijack, but just a quick question about custom plate mounting on an r33 S2.
the polycarbonate 9 letter plate is 375mm long, which doesnt actually fit in the stock plate are.
has anyone overcome this problem? any ideas?
cheers
BTW there is a black 180sx with like glitter paint going around with [bOOSTED]
https://www.sau.com.au/forums/topic/223093-custom-plates/#findComment-3959215
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
    • Thanks Paul I reached out to Autotainment but they no longer work on JDM cars as the guy who used to do the work moved on and is no longer doing that kind of work. I am talking with Level Up Audio though.
