  • Replies 153
Originally posted by WazR32GTSt
did anyone cop a speeding fine?
i would love to come and meet/cruze with you guys but
1) i don't speed for no reason, and
2) my car wouldn't keep up with all of yours...!
you're welcome to come on any cruise.
I'll keep ya company if ya dun mind cruising along with an older guy :)
as I'm getting older I'm getting more scared than 10 yrs ago...
so I also don't speed for no reason, and mild mods on my car wont keep up with some other beasts out there. stock tyres, stock suspension, stock turbo...
True.
Cruising through GOR, you'd miss a lot of beautiful scenery if you go too fast... kinda the right way to sit back for relaxed cruising, enjoying the scenery, just like when I travelled to Tasmania....
Originally posted by RedLineGTR
yah but speeding is much more fun.....
Go to the track. Safer with lots of run-off areas in case you overshoot a corner.
boom there is the limiter...oh well...
Get Apexi RSM or PowerFC :-), oh and a matching speedo.
Originally posted by rs73
True.
yessss, max knows all about that ey max? :)
Dan got the photos developed but they came out really bad man!!
Blame it on at your work haha. Took it there and their machine stuffed up, had to wait for a while, printed the wrong size and the colour are really dull. The gave me 2 copies though, you can have the other set if you want. But nothing flashy or pro.
Guys the GOR was great fun, but some bit was like a race just to keep up hehe. I guess that is what happy when there is open straight road with 20 odd Skylines haha.
Maybe the next cruise should be a nice relaxing one not too far. Something to show off our cars hehe. Anyone for a Chapel St Cruise haha j/k. 20 cars go in 5 cars come out, the rest CANARY hehe.
The GOR cruise has speed limit of 80-100
Nothing wrong taking a corner at that speed limit if both your car and you are capable to do it. I know my car can't, shocks could be worn, tiny stock rear rubber, I was only doing 40-60 on most tight corners. that's like at least 20kph below the limit.
    • Unfortunately,  it feels like it's been on the decline for nearly a decade. Especially as wallet racing became popular with them(biggest wallet can pay off a car that wins). It seems like a different mindset kf ownership these days. But, hopefully people like yourself keep some of the skyline scene alive.
    • A bit of data is always good, beats the Facebook experts with their opinions Although the kWs aren't anywhere near what you are after, it should give you a good indication. I have Bosch 1480cc injectors, often called 1650cc (only when run at 4bar). I run mine at 3bar base so I don't thrash the fuel system. Up top, making 437kW with boost dropping, injector duty is at 69% on E80 (might have had some residual 98RON in there)
    • I have some downtime due to winter, and just wrapped up converting the car over to flex fuel. We don't get E85 at the pump over here in Canada, but I will be running Ignite E90 Race gas. I'll be mixing it with 99-100 RON pump gas and shoot for 50% ethanol content, up to possibly 85% content if there's any noticeable gains. Here's the question. Most I'll ever want to hit is ~600rwkW. I've currently running 1200cc injectors and want to keep them under 90% duty cycle. As per some online injector calculators, I should be good with 1200's well past 600rwkw on E85. As per other calculators, I'll need 1600-2000cc's. The variety is rather amusing.  With you Australians having E85 at the pump, what realistic duty cycles are you seeing in those kW ranges on E50 & E85 on your injectors? Thanks,
    • No issues here with my PRP gears in an OEM pump housing. I did confirm all housing clearances were to spec prior though. Cheers.
    • Thread is a bit old but figured id give my input anyway just incase. Have had lots of water problems in my R32 and was getting sick of wet tools in the boot and water filling up half my taillights. I ended up finding that whenever my car had been repainted they didn't reseal the taillights to the body of the car so water was just flowing straight into the boot, this is amplified by all the water around the bootlid being directed down to the taillights so would get pretty wet whenever I washed the car or it rained. You could probably use silicone to seal them to the body but I think from factory they use a roll of automotive grade butyl rubber. Hopefully this helps you if that ends up being how the water is getting in on your car!
