Looking for some pics of GTSt which has had the std guards pumped a little to clear bigger rubber. Not interested in fibreglass flares, just looking for pics of an R32 with steel guards tweaked etc.
Have seen it on plenty of S13s and looks great. Only the R32 has a pronounced guard line and not sure if it will look any good on an R32 GTSt. Alternative is GTR guards which i am trying to avoid. But whilst OS want the car left with panel beater so this can be done in the near future
fronts ive got 20mm fenders, couldnt find anyone that could flare my guards.
my p1s are 17x9 +17 the rears atm have 255/45/17 (could do with a 20mm spacer and 235/45/17 tyres to make a better fitment.)
fronts are 17x9 +17 with a 10mm slip on and has 235/45/17 sits pretty flush but i would like to try and sit a 15mm in it.
racing harts were 18x8.5 +21 235/45/18 / 18x9.5 +21 275/45/18.
why are you trying to avoid gtr gaurds? the fronts would not be too expensive.
Think Roy is refering to the rear more so in reference to avoiding GTR guards, which is either an add on FG panel, or a cut/merge & repaint job.
Fronts require a couple of other changes (indicator & maybe front bar?) and isn't as cost effective as rolling guards.
If a big fan of a well done guard rolling job, esp. to fit deeeeeep dish rims :ninja:
Love that pic of the matt black 32 finshed with the GTR front bar :blink:
Well, partly because its a GTSt and i want it to saty looking that way. Partly because the change to indicators, side skits, front bar etc etc is a ball ache, and the rear qtrs need to have the innter guards and fuel filler neck etc done as well which is a more costly job. So, lol yeh, mostly money and complexity for a car that is a track car and likely to eat armco again sooner or later :D
just sprayed the quaters.
but yeah roy, you'll be able to fit a fair bit of rubber (with 18x9.5 +21 with 275/45/18 i still had heaps to play with.) if your flared your rear guards.
fronts ill suggest you get them lipped or go for the gtr guards.
Edited by SoFly
ok thanks man
I need to flare my rear and fronts to fit my new wheels in
How had are the fronts to do and do they come up good or do they need a lot of work?
Did you use a proper guard roller or did you use the dodgy newspaper method lol
Thanks again
Piss of Abu :D If we end up with simialr gaurds then our cars are going to be too similar :D Actually thats not a bad thing :D
lol
Trying to copy my style hey!
What wheels you got Roy?
I just sold my R33 GTR wheels and bought something a little more crazy, but won't say too much at the moment :)
We should combine your R32 with my R32 then we'd have the ULTIMATE streeter R32 :)
    • Nah it factory manual not sure about ratio but it looks like there’s been some work at the rear
    • so I need a new speedo cable
    • Throwing my spoon to the soup here a bit.  When I installed a 044 back in 2012, along with the direct power mod, the car became very difficult to start. To a point I burned one starter motor as I was late for work and tried to get the thing going. With some tuning and careful use of gas pedal when cranking it became bearable. Trying to make this short as possible, but the 044 died after 2-3 years, after which I went with an AEM 320lph pump, which also died after about 4 years to my dismay. After that I went with a Nismo pump, and while trying diagnose an emissions problem, I noticed for the first time that my fuel pressure was 5bar/72psi on idle, and that removing the vacuum line did nothing. After monitoring the situation, and removing the direct power feed and going back to FPCM in attempts to remedy it, I noticed there was fuel in the pressure regulator vac line. Kept the FPCM, installed AEM external regu and the car became sooo much better in every way, including starting. And I had driven it like it was for 11 years.. Anyway, I agree these are likely two different problems, and the FP problem you just haven't noticed before. I do not know much about haltecs, but what first came to mind was the CAS, which probably is not there any more. So how is the wiring from haltec to gauge cluster? How is the battery voltage and alternator?
    • Your car was auto before? You have different diff ratio (auto vs manual i think? or n/a and turbo?)
    • +1 for getting a screen off alibaba, CarPlay/Android Auto is vastly better than whatever navigation cars had 10 years ago. I got an Android screen for my 2015 BMW, huge difference. Fully compatible with factory stuff including iDrive controls.
