Hi all, a quick question here re set up on an safc blue screen model, not the latest.
When setting up the sensor type, after entering hotwire, do I enter 4 (my sensor type no, r33 gtst,) in both the IN and OUT fields, as I found the instructions a little hard to follw at this point.
Any clarification here would be appreciated.
Cheers
Harry :P:(
https://www.sau.com.au/forums/topic/22311-s-a-f-c-set-up-question/
i was also wondering this... what is the effects of having the wrong number in this field???? and also the screen after that where is goes to the sensor cal screen where i think its for 2 afms etc.... do u just leave that at 1 and 1 also?????
Originally posted by pushead
EXACTLY WHAT I WANTED TO KNOW!!!.. bumping this post.
The Apexi manual shows GTST R33 = HW4
So that means in the hotwire mode i enter in the IN field4 and the Out field 4 as well?
Thats right, It means Input from the AFM =4 Output to the ECU =4 .If you have a different AFM like a Z32 then it would be Input =3(just example number) Output =4 .So the safc converts the Z32 Afm to a Stock signal and the ecu doesnt notice the change.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 馃槂
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
