hey all.. i currently have just finished setting up my new turbo setup on my rb20 cefiro...
i have gtr injectors alreayd cleaned and flow tested and the dropping resistor which is need for the gtr injectors..
my question is once i have the injectors installed and resistor pack installed will the car run at all... i know it owuld be extremely rich if it did run at all
all i need is for it to run for maybe 2 hours, off boost so i can drive down to get a remap on my stock ecu...
cheers in advance :)
https://www.sau.com.au/forums/topic/223139-gtr-injector-help/
With the power fc set on standard factory map we couldnt get the car(R32 RB20) to start after installing GTR injectors and resistor pack. We had to adjust the injector correction i think from memory using a calculation that is on paulr33's write up on power fc's.
So I dont think it will run, if u turn it over and it just keeps cranking then that will be the problem.. Just make sure when you brigde your resistor pack you are 100% the wires are connected/soldered properly.
