R34 Gtr Turbos $790
Item: R34 GTR turbos with stock actuators
Age: 2000 model
Condition: excellent
Price: $790 for the pair
To Fit: (What car) Anything with RB26
Contact: Jerry via pm or email: [email protected]
Comments: excellent condition turbos , they were replaced with aftermarket . These are ball bearing and bigger than R32/33 turbos , the car they came off was running standard boost ( no boost controller )
I have a pair of N1 actuators if anyone wants them at additional cost .
Hey mate i thought that the N1 R34 turbos were steal wheel not ceramic?
Postage cost to Melb?
Cheers
I never said they are N1 Turbos, they are stock R34 GTR turbos ( came off a V-spec). I do have a pair of N1 ajustable actuators for additional cost if anyone wants them , use them and you don't need a boost controller
Post to melbourne metro, about $20 via Aussie post +rego and Insurance if needed about $10.
Age: 2000 model
are they steal turbines
Hi Jerry...reading and interpreting the english language is somewhat difficult for some people.
guys these turbo's would be mint, good luck with the sale mate.
That's two that don't know the difference between 'steal' and 'steel' Paul , you wander what they learn at school these days .
For the ones that don't know the exhaust wheels are " inconel", a nickel-base alloy with chromium and iron, used in gas-turbine blades . Inconel alloys are typically used in high temperature applications, There are lots of different grades of this exotic alloy with different properties.
Inconel 600: Solid solution strengthened
Inconel 625: Acid resistant, good weldability
Inconel 690: Low cobalt content for nuclear applications
Inconel 718: Gamma double prime strengthened with good weldability
The above are some, probably lots more, not sure which one garrett use in the RB26 turbos.
When people refer to RB 26 turbos as 'ceramic' its incorrect they are not ceramic however when they smash they become tiny little pieces .
The so called steel wheel turbos , are not steel either, a magnet will not stick to them, some kind of alloy as well .
If anyone wants these temp me with an offer, even a silly one otherwise they are going on E-Bay, I don't feel like keeping themto do a swap in my car when time comes to sell it..
  • 3 weeks later...
 Share
    • That's true. However, this problem has started since the tuning. First time with the return journey from the tuning. But yes, the pipe was clogged with dirt and rust. That was certainly due to age
    • Great info @tidi0x  Will definitely be handy for others and maybe me if I decide to keep the shit box H pattern.
    • Bumping this up one last time.... I wanted to follow up on the clutch slave issue. I realized that what the issue comes down to is the pocket is flat milled, and the cylinder does not want rest flat. So in order to mount it correctly you will need to make a spacer for the fingers so the cylinder is floating. I took two plates of aluminum, drilled some holes and was good. I did still need to make the relief cuts in the bell housing, as even with the spacer the bleed section still interferes. The OE bell housing the mounting holes are raised from the housing.
    • If the event in USA goes ahead will be interesting as it seems the rules will get more cars over here. Apparently the track is laguna seca too. Yeah s15, if I get a the lower dash trims, centre console and change front cross member to standard LCA position will fit clubsprint. See how rules are as i would rather do complete widebody than a bolt on flare to run the 295 with proper clearance.
    • If the car is legal height I can't see it being an issue. Found a thread on reddit that might offer some insight.   I got a ticket from a copper in QLD for my S15 being too low. They had this wheel thing on a stick that they put under the car and it hit my exhaust. Anyhow went to an exhaust shop to get the exhaust tucked up/hung a little higher and I wound the coilovers up a smidge. Don't think I even had to go back to the police station unlike when I got defected for having a carbon bonnet when I brought the S15 from the ACT to QLD and had to replace it and then rock up at a police station and have a yougish female officer who knew nothing about cars confirm that I had changed bonnets. Should have just painted the carbon bonnet yellow to match the rest of the car lol
