Item: R34 GTR turbos with stock actuators
Age: 2000 model
Condition: excellent
Price: $790 for the pair
To Fit: (What car) Anything with RB26
Contact: Jerry via pm or email: [email protected]
Comments: excellent condition turbos , they were replaced with aftermarket . These are ball bearing and bigger than R32/33 turbos , the car they came off was running standard boost ( no boost controller )
I have a pair of N1 actuators if anyone wants them at additional cost .
https://www.sau.com.au/forums/topic/223185-r34-gtr-turbos-790/
Do there still have a ceramic wheel like all the other turbos?
Same material as all standard GTR turbos dude.
jivlah : You can fit them on anything you want with the right exhaust manifolfd
Hey mate i thought that the N1 R34 turbos were steal wheel not ceramic?
Postage cost to Melb?
Cheers
I never said they are N1 Turbos, they are stock R34 GTR turbos ( came off a V-spec). I do have a pair of N1 ajustable actuators for additional cost if anyone wants them , use them and you don't need a boost controller
Post to melbourne metro, about $20 via Aussie post +rego and Insurance if needed about $10.
Age: 2000 model
are they steal turbines
I still have these ...
Hi Jerry...reading and interpreting the english language is somewhat difficult for some people.
guys these turbo's would be mint, good luck with the sale mate.
That's two that don't know the difference between 'steal' and 'steel' Paul , you wander what they learn at school these days .
For the ones that don't know the exhaust wheels are " inconel", a nickel-base alloy with chromium and iron, used in gas-turbine blades . Inconel alloys are typically used in high temperature applications, There are lots of different grades of this exotic alloy with different properties.
Inconel 600: Solid solution strengthened
Inconel 625: Acid resistant, good weldability
Inconel 690: Low cobalt content for nuclear applications
Inconel 718: Gamma double prime strengthened with good weldability
The above are some, probably lots more, not sure which one garrett use in the RB26 turbos.
When people refer to RB 26 turbos as 'ceramic' its incorrect they are not ceramic however when they smash they become tiny little pieces .
The so called steel wheel turbos , are not steel either, a magnet will not stick to them, some kind of alloy as well .
If anyone wants these temp me with an offer, even a silly one otherwise they are going on E-Bay, I don't feel like keeping themto do a swap in my car when time comes to sell it..
  • 3 weeks later...
    • All I can say Duncan is good luck and I hope that Neil did not run any E85 in Cheryl. I have recently experienced the full spectrum of fuel tank issues in my R33's that had been caused by E85 and contaminated fuel. When you take the cover off the top of the tank and have a look inside you will get an understanding of how easy it will be. Best case situation is clean fuel with minimal contamination. My GTR was like this and it was a very simple operation to just grab the fuel pump carrier bracket and slide it up and out of the tank. My three GTS_T's had different levels of fuel contamination that was probably caused by E85 in the fuel.  In the worst case all of the metal components in the tank had rusted to the point where there were pieces of rusted metal swirling around in the tank. This required the removal of the exhaust, the tailshaft, the complete rear cradle and the fuel tank. The components in the tank were that rusted that it took days to get the fuel pump carrier and the mounting brackets out of the tank. When the tank was finally cleaned, everything inside the tank had to be replaced. With the tank all back together I could then reinstall it in the car along with everything else that had to come out. Good luck and I hope that you find a clean tank.
    • It is a two door. It is black and also still has the OEM wheels and stereo. Exact model would be KR_R32RGFEL_SS According to GTR-Registry.com is a 2 Door Coupe; RB20DE; 2WD no HICAS; MT.F5; (11L) Projector Headlamps and Fog Lights; (12_) Electronic Active Full Auto Air Con (Climate Control); (13-14SS) V Selection -- Which seems to be accurate description of my variant. Will try to upload a few pictures soon. The OEM wheels look like the below image. Image is taken from the goo-net-exchange website.
    • Time: Saturday 18th January - 9am -10:30am Where:  Cafe By Lamanna 10 English St, Essendon Fields VIC 3041  - https://g.co/kgs/mhVKvAB Registration: So we can give the cafe a heads up on rough booking numbers please rsvp below Registration Link: https://forms.gle/wPtfj9Gp8bvCiouo8
    • Welcome Gabriel. At least your car has a glorious RB and not the shitty CA18. As MBS206 mentioned all the good bits can be added later. Two doors or four?
    • And half of them have been converted to turbos.
