lol thats your exhaust cam buddy.
are they the stock cams or have they been removed or installed recently?
usually they break when installed incorrectly.
but in this case it seems the cam bearing cap has either had a bolt break off or fall out (hard to tell in pic)
then you can see the other side closest to the ex manifold has been flogging itself to death, because its trying to hold the cap on with only one bolt. hmmm to fix it is probally gonna require a couple of helicoils, and some new cams.
Edited by dangerman4
are they the stock ones or have they been removed or installed recently?
but could just be bad luck..
oh oops lol sorry im not that good with all this,
they are standard, i did have a problem with one of the back baffel plates coming loose, this car has been some what of bad luck, but i've stuck with it. how do i get the cam out is it something i can do or does a pro need to do it, due to any timing measures or anything
1st post edited
if your unsure on how to remove it i would take it to a head specialist and get them to do it , as you mention you have had isssues with this allready so you may have buggered it up yourself by doing the cap up to tight or not tight enough etc.
buy some new cams and then get a pro to fix it or at least someone compitent enough to fix those 2 stud holes.
When taking the retainers off you slowly release each one gradually so it supports the cam where the lobes may still be against the lifters. Ppl cut sick and take them completely off one by one which = above.
You fix it by buying a new cam now, if you have not removed the cam previously then I would say it may be running a mismatched retainer possibly from another head. This can also cause this to occur.
Edited by James_03
ok so buy a new cam, would there be a site where i can purchase this? and u all reakon i cant do this myself, i guess i wont this problem to go away
as i said before i did have a problem with the baffel plate, it actually broke one of the bolts that hold it into place, i had to drill it out and try and rethread it, cant say i did the best job so im assuming i caused the problem lol. u knowing this now will it be better to get a new/second hand head to save any hassel??
My guess is that you may have accidently over tightned the bolts holding down the retainers when you fixed it previously, or possibly mismatched the retainers. Each retainer is numbered in order and also must go the correct way up, the nissan service manual will then state the correct torque settings for each bolt, and the order in which they must be done up.
I would say its unlikely the valves have sustained any damage yet. Your best bet would be to pick up a set of second hand gtr cams, the best place to source them is most likley here off the for sale forums as people upgrade cams frequently. Once you have done that take the head in to a specialist to have them check all the tolerances out and pressure test whilst your there, if you do go this way get the stem seals replaced whilst your at it, and get a price on a valve regrind.
That's a pretty big job but as it involves removing the head obviously, so you could get away with simply fitting another second hand exhaust cam and check all the retainers and torque settings are correct. Make sure you use cam assembly lube, then turn the motor over by hand to begin with and make sure it does not lock up at any stage. Then again before starting remove the CAS connector, and perform a compression test on the motor by using the starter motor.
Compare this comp test with the factory settings to know if you have possible valve damage, then you have no choice but to remove the head. Remember with both cam's torqued down you should be able to move both intake and exhaust cam wheels by hand, not too much but as you will make contact with the piston crowns if the head is still torqued down, if you cant move the cams slowly in either direction is not right.
Edited by James_03
i thought it was a conrod? LOL its funny that you laugh at what has happened dude it cracks me up!
what else can i do but laugh, its done and now i have to deal with it. if i took to a pro to start off with i wouldnt be in this mess, but thanks for ya input slaughter. LOL
thankyou so much james, you seem like you know your stuff, its people like you that make this site what it is, (very helpfull). I'll be coming to you if i have any more qauries. i'll be intouch. regards - nathan.
thankyou to everyone else too. it all helps.
    • Yep super expensive, awesome. It would be a cool passion project if I had the money.
    • Getting the setup right, is likely to cost multiples of the purchase price of the vehicle.
    • So it's a ginormous undertaking that will be a massive headache but will be sorta cool if pulled off right. And also expensive. I'm sure it'll be as expensive as buying the car itself. I don't think you could just do this build without upgrading other things to take the extra power. Probably lots of custom stuff as well. All this assuming the person has mechanical knowledge. I'm stupid enough to try it but smart enough to realize there's gonna be mistakes even with an experienced mechanic. I'm a young bloke on minimum wage that gets dopamine from air being moved around and got his knowledge from a Donut video on how engines work.]   Thanks for the response though super informative!
    • Yes, it is entirely possible to twincharge a Skyline. It is not....without problems though. There was a guy did it to an SOHC RB30 (and I think maybe it became or already was a 25/30) in a VL Commode. It was a monster. The idea is that you can run both compressors at relatively low pressure ratios, yet still end up with a quite large total pressure ratio because they multiply, not add, boost levels. So, if the blower is spun to give a 1.4:1 PR (ie, it would make ~40 kPa of boost on its own) and the turbo is set up to give a 1.4:1 PR also, then you don't get 40+40 = 80 kPa of boost, you get 1.4*1.4, which is pretty close to 100 kPa of boost. It's free real estate! This only gets better as the PRs increase. If both are set up to yield about 1.7 PR, which is only about 70 kPa or 10ish psi of boost each, you actually end up with about 1.9 bar of boost! So, inevitably it was a bit of a monster. The blower is set up as the 2nd compressor, closest to the motor, because it is a positive displacement unit, so to get the benefit of putting it in series with another compressor, it has to go second. If you put it first, it has to be bigger, because it will be breathing air at atmospheric pressure. The turbo's compressor ends up needing to be a lot larger than you'd expect, and optimised to be efficient at large mass flows and low PRs. The turbo's exhaust side needs to be quite relaxed, because it's not trying to provide the power to produce all the boost, and it has to handle ALL the exhaust flow. I think you need a much bigger wastegate than you might expect. Certainly bigger than for an engine just making the same power level turbo only. The blower effectively multiplies the base engine size. So if you put a 1.7 PR blower on a 2.5L Skyline, it's like turboing a 4.2L engine. Easy to make massive power. Plus, because the engine is blown, the blower makes boost before the turbo can even think about making boost, so it's like having that 4.2L engine all the way from idle. Fattens the torque delivery up massively. But, there are downsides. The first is trying to work out how to size the turbo according to the above. The second is that you pretty much have to give up on aircon. There's not enough space to mount everything you need. You might be able to go elec power steering pump, hidden away somewhere. but it would still be a struggle to get both the AC and the blower on the same side of the engine. Then, you have to ponder whether you want to truly intercool the thing. Ideally you would put a cooler between the turbo and the blower, so as to drop the heat out of it and gain even more benefit from the blower's positive displacement nature. But that would really need to be a water to air core, because you're never going to find enough room to run 2 sets of boost pipes out to air to air cores in the front of the car. But you still need to aftercool after the blower, because both these compressors will add a lot of heat, and you wil have the same temperature (more or less) as if you produced all that boost with a single stage, and no one in their right mind would try to run a petrol engine on high boost without a cooler (unless not using petrol, which we shall ignore for the moment). I'm of the opinnion that 2x water to air cores in the bay and 2x HXs out the front is probably the only sensible way to avoid wasting a lot of room trying to fit in long runs of boost pipe. But the struggle to locate everything in the limited space available would still be a pretty bad optimisation problem. If it was an OEM, they'd throw 20 engineers at it for a year and let them test out 30 ideas before deciding on the best layout. And they'd have the freedom to develop bespoke castings and the like, for manifolds, housings, connecting pipes to/from compressors and cores. A single person in a garage can either have one shot at it and live with the result, or spend 5 years trying to get it right.
    • Good to know, thank you!
