I need parts to build an RB30det
1) RB26 head. inc intake manifold. Complete prefered
2) RB30e Block series 2. inc crank and rods
3) R33 GTR oil pump
4) R33 GTR water pump
5) RB25det manual G/box
Parts that will be for sale/swap or trade:
1) Rb20det. minus turbo. have R32 crossmember also $offer
2) RB20det manual and auto G/box $offer
https://www.sau.com.au/forums/topic/22320-rb2630-parts/
Where's the truth in your words??
So you've been offered a cheap RB26dett? (sure..but I'd like to let you know there is no such thing, as a cheap RB26)
You've been offered some of the parts that you were after and at good prices, but still haven't made the move.
I'm reading between the lines...your a dreamer, who talks and plays off the bench.
Nothing wrong with Dreamers......we all would like parts for peanuts.....but some of us don't go around spreading it and wasteing other peoples time.
Try posting only when you want the parts.
Phil.
https://www.sau.com.au/forums/topic/22320-rb2630-parts/#findComment-487538
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
    • Hope the cans went down well at least
    • 255 can't go wrong with the price.
    • When I was replacing my pump due to being stranded in the wrong state, I went with the Deatschwerks 320lph kit. It is a direct plug in to the stock wires, harness, everything. It comes with a plug... but you can plug the OEM plug directly into this thing. https://justjap.com/products/deatschwerks-dw300-fuel-pump-nissan-s13-silvia-r32-r33-r34-skyline-c34-stagea?currency=AUD Downside: Won't actually flow that much on boost if you want to push it on E85, but it's comparable to the 040/255 etc. Little more actually.
    • I dunno what the "best" one is....but when my 040 died late last year, after about 20 years of screaming service....I put in a 255. Like any such thing, you have to finagle it a little bit - it's not a no-brain swap. But it's not hard.
