I want to buy a cf drive/prop shaft for my car from the current group buy,
Only my car is an R32 GTSt which will be running a R33 gearbox and normal rear end.
I figure since i need to mod the prop shaft i may as well get a new one. So does anyone know from their RB25 gearbox conversion whether the shaft length is any different? Shorter, longer? Or is it just different connections?
https://www.sau.com.au/forums/topic/223212-rb25-gearbox-conversion-into-an-r32/
  • 5 months later...
Hmm. probably need to just wait and confirm length of tailshaft whenever the 20 box blows
Sorry to bring up old thread, Roy did you ever end up putting the 25 box in your r32? Just wondering how did you solve the speedo sender problem if you have? Been doing my head in figuring out where to get the bits from in melbourne, having a little trouble tracking down a Navara speedo sender (dont know what year Navara and being told no longer stocked by others), i am not too confident with cutting and shuting bits and pieces to come up with a reliable solution, would much prefer a drop in option even if it is a bit more. You reckon you could throw any leads my way?? Cheers
Rob
You can get away with just dropping a Navara sender straight in if you have taller diff gears..
I put 3.9s in mine and the 17T Navara sender resulted in my speedo reading 7kmh high, perfectly fine as far as I'm concerned :blink:
If you don't have any luck finding a part number, shoot me a PM, I think I've still got the box at home somewhere.
Playing with the sender myself at the moment. Got a navara sender and chopped off the gear as I have a 4.3 diff.
Pulled the cog from the 33 box and now not sure what way to go about attaching the 33 cog to the navara shaft?
The 33 senders cog was just attached with a circlip and the navara cog was moulded on meaning the shaft from the navara sender is full circle whereas the shaft from the 33 sender was alkf moon on the end.
So...I'm left with a cog thats half moon through the centre that needs to be attached to a full circle shaft. The cogs from the 33 are no longer available so dont want to muck it up. How have other people gone about it? My best thought was to get a dremel and small grinding stone and slowly chop it away?
I have posted the solution to this problem so many times I've lost count.
Some others here have slowly caught on.
If you can't be bothered searching get a sharp round file and carefully make the half moon in the 33 cog perfectly round.
It will be a nice press fit onto the navara splined shaft and shouldn't need glue.
Don't forget to recut the location slot on the navara speedo drive 180 degrees opposite the original slot or it will only last a short while.
Touche mate.
I ended up searching and found the answers...many times over lol. I think I may go with grinding down the navara shaft though. Coz if I stuff up I can get another one. I also found that the R32 GTS4 has a 21 tooth cog. Cant find out which way the teeth are cut though....
    • Yes, I know🙄 but the sequential is not in my budget... don't want to reduce power neither, so looks like I'm stuck in the rabbit hole🤣
    • You’ll be very upset when you bust that too not to mention the gearing totally sucks. Don’t do it.
    • Is the panel filter one that is oiled? Have you ever cleaned or touched the AFM?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
