i have got a highmount on my rb20 as well and that sits very high as well not alot of room there but mine does fit and mine sits up near on the same high as yours,it will go right near ya strut tower if you have got a strut brace it wont fit cause ya turbo will get into the way as well. just make sure when ya put ya pipe into the turbo that the bolts dont hit it as well cause i ahd to stuff around with mine for a while. sweet looking set up good luck
Ok Decided to bite the bullet and put the engine back in the car with the turbo on it to see if it clear... Lets jsut say its pretty dam close.
And don't you hate it when you pull your bonnet out of storage and after rapping it in a doona you find this!!
Yea have thought of a few things, a beie should fit under there, have to jack the back of the bonnet up 3 or 4 mm as i didnt put the washer back under the hinges to bring it up level with the guards.
I need to get some flame/heat wrap to put on the under side of the bonnet, any idea where i get it?
    • This was a huge help.  We followed the steps,  although shifting into 2nd was actually into 3rd for us,  and 1st was into 2nd ( steps 9 and 11) .  The long flash was the 4th flash.  So shift solenoid A is possibly the culprit.  Is this inside the transmission itself? Or is it accessible by just front the pan? Or is it bolted to the outside of the transmission?  Thanos for your help everyone
    • Can you enlighten me on your best practice regarding these hoses? I don't wanna make the same mistake if you already got a better solution.
    • I have some silicon hoses already, for example engine to watercooler. But yeah, I get the sentiment. The lower intercooler silicon hose is drippy too, despite not being very old. Does anyone except Nismo make these same lines out of rubber? Long term I think they'd be the better replacement, especially since the car won't live as hard a life anymore as in the past nor be driven as often.
    • I know most issues are just age related. But for example the turbo oil drains, there is dash adapters for these and you can just make a braided teflon line for them and (probably) never have them leak again. Also not terribly expensive. Can you even get the factory hardlines from new? Or are they repairable if they break?
    • I know it'd be much much easier with the tool. I hope I can find one that won't take 3 weeks to get to me an isn't a "Asian models kit" that has tons of (to me) useless adapters for a load of cash.   It's a summer project/fun car. I do wanna enjoy it, without endless downtime over and over. So yeah I would even go and buy an engine crane + stand to save myself the trouble of hard to reach or unreachable places going bad later on. Would also be a good opportunity to put on a Fluidamper, renew the mains seals and stuff like that. I have some money on the side that I can use for that, what I wouldn't want to or be able to do is let everything be done by a shop or have my engine completely rebuild right now. I intend to do most of the "doable" jobs myself. Pulling an engine can't be that hard, can it?
