well i own a GTS T R 33 and this afternoon as i was making my way home i come across an R 33 GTR V-Spec, (well yes the car of my dreams!) so slowly i creep behind as we aproch the lights! the driver notices me and gives a little grin (mind you driver is roughly in his 40's) lights are green and he lets the clutch out leeding me to belive he is just another old fart driving a magnificent car at only a quarter of its potential, but then with a fuel dump bluring my vision for a split second he was gone! wow its on. releasing all possiable horses i grab the stick shift to second then third pulling beside him at the next red light!
his wife also older giggling and smilling as i chuckle and listen to the sound of two magnificant cars stalling at about 2200rpm (well thats what i was at) lights are green and where off (RACING) so off the lights wheel spinning (as all GTS T's do) i find my self only half a GTR behind as i click second feeling the rear trying to pass me still as try to retain traction slip to third out to about 6600rpm and were both off the gas pop to fith and puring down the road like a quire on a perfect note. but only finishing half a car behind???
THIS HAS ME PUZZLED! i understand his only got .1 of a litre more but one extra turbo and probbably 15,000 dollars more for roughly .500 of a second quicker. i dont no, was he just playing or was it seriously close??? this has NOT changed my mind of course i still want one but maybe not for the power anymore!
any thoughts would be great!!!
https://www.sau.com.au/forums/topic/22323-gts-t-or-gtr/
First of all, the RB26 is internally a lot different from an RB25 other than that 100cc difference......combined that with ATTESA, a properly launched GT-R won't let U down.
you only have to look to other 4wd cars like the EVOs to match it's 'off-the-line' response....or the midship NSX-R.
https://www.sau.com.au/forums/topic/22323-gts-t-or-gtr/#findComment-478837
ECR 33 - having gone from a semi-modded R33 Gtst (Series 2) to a virtually bog-stock (at the time) R33 GTR. I can assure you that he was taking it easy, or couldn't drive. The GTR's have a MUCH more advanced engine and gearbox (longer gears etc) and are considerably faster than a Gtst.
If you were in Sydney, i'd take you for a drive in mine..
Christian
https://www.sau.com.au/forums/topic/22323-gts-t-or-gtr/#findComment-478838
    • Hi All, I'm based in Sydney and want to get hold of 4 stock R34 GTT wheel caps as pictured. Cheers
    • Haha im flattered! Although my poor boat is collecting dust in the garage, as it hasn’t been driven in like 6 months. I forgot the to put the trickle charger on too, so the battery is likely toast now.. I have the frenchys kit. It is fantastic. My only gripe was that the hard lines from the firewall needed some tweaking, however, this was mainly due to my specific turbo and dump combo. The weight and size packaging is much nicer too. I think I have some pics on my build thread somewhere.. my justification for the kit was more “why not” I had gone to the trouble to modernise just about every other part of the car..
    • Actually, ethanol has probably never been cheaper, on a tax free basis, than petrol. With fuel excise being what it is, and only being levied on the hydocarbon component, not the ethanol component, and ethanol for non-drinking purposes not being subject to liquor excise - E85 was cheaper, but not because the combustible liquid itself was particularly cheaper.
    • Maybe? If changing the cat to a higher flowing cat, caused the turbo to spool more quickly, and those areas of the map had not been tuned for the boost level it is now seeing, then yes you would need a re-tune. How dangerous it is running without the updated tune would depend on how far out the tune is with the now higher boost levels, how the engine protection has been setup, is the ECU compensating with a wideband sensor, is the boost control closed loop blah blah million other things... But yeah having said that, I wouldn't be surprised if changing out the cat for a high flow, in say a full 3" exhaust, made no noticeable difference at all.
    • Ah yep. I asked a auto electrician about getting a cheap rebuilt alternator vs a new one. He also said he used to it back in the day but it ended up costing similar to what a new one would and recommended getting a new one,.
