  • Replies 81
Wish I had longer than 30 mins for lunch so I could actually meet with some SAU peoples. I have just enough time to eat, grab a drink and have a smoke. Being on the 40th floor can have disadvantages. It takes almost 10 minutes to catch the lift down, have a smoke, and catch it back up.
Paul - Level 9 you say... You supporting Corporates or just general support?
I'm down @ 35 a fair bit... Usually up on level 15-21 though.
Cheers,
matt
hey lowth
yeah im on level 9 and occasionally level 17
im under customer network operations
our customers are corporate
who do u work for and what department do u come to see
Hey mate,
Will PM you the specifics! :P
hey lowth
Hey mate,
Will PM you the specifics! :)
noooo tell meeeeeeeee! :)
Well I think Kane is up for lunch this week.. Paul? anyone else??
(will be cnr collins/exhibition area to clarify, as opposed to Southbank!)
I seriously need decent Vittoria coffee.. someone tell me where to buy this rare liquid!?
So sick of all the CRAP coffee in the area.
Construction/development management. Are you in the area too?
I have seen a few SAU people/cars around this area lately.
I work at 99 Queensbridge St... Administration Assistant :O
Although you wont see my little sh!tbox around, im usually already parked somewhere by 8:30am & straight onto Kings Way at about 5:30pm...
Haha, same as me, my car is tightly tucked into a car park all day. Nice and snug, next to a very nice WRX STI. We're car buddies although we've never actually met.
it's a bit like that at my flat. out of just nine car spaces we have a WRX, S15 and an R34 tucked together but i've never bumped into the owners.
Hey if anyone here works in telstra and knows of any open positions, let me know as i wanna change where i am now. Im in PODS and DTOW held orders for home phone, just want something better than 33k a year. PM me lol cheers
Assuming you can get to this page (Telstra Only)
http://www.in.telstra.com.au/ism/telstraca...ities/index.asp
:banana:
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
    • Yes. Imagine you have the car on the ground, and you mine away all the ground under and around it, except for the area directly under each individual wheel. That's exactly how it'd look, except the ground will be what ever you make the bit under each wheel from
    • Yes, if you set the "height" right so that it's basically where it would be when sitting on the wheel. It's actually exactly how I tighten bolts that need to be done that way. However....urethane bushes do NOT need to be done that way. The bush slides on both the inner and outer. It's only rubber bushes that are bonded to the outer that need to be clamped to the crush tube in the "home" position. And my car is so full of sphericals now that I have very few that I need to do properly and I sometimes forget and have to go back and fix it afterwards!
    • Discover the best Halal food near you with Maharajaonline.com.au. Our delicious selection of Halal dishes will satisfy your cravings and make you feel like royalty. Try us today and experience the difference!   halal food near me
