well i own a R 33 GTS T and this afternoon as i was making my way home and i come across an R 33 GTR V-Spec, (well yes the car of my dreams!) so slowly i creep behind as we aproch the lights! the driver notices me and gives a little grin (mind you driver is roughly in his 40's) lights are green and he lets the clutch out leeding me to belive he is just another old fart driving a magnificent car at only a quarter of its potential, but then with a fuel dump bluring my vision for a split second he was gone! wow its on. releasing all possiable horses i grab the stick shift to second then third pulling beside him at the next red light!
his wife also older giggling and smilling as i chuckle and listen to the sound of two magnificant cars stalling at about 2200rpm (well thats what i was at) lights are green and where off (RACING) so off the lights wheel spinning (as all GTS T's do) i find my self only half a GTR behind as i click second feeling the rear trying to pass me still as i try to retain traction slip to third out to about 6600rpm and were both off the gas pop to fith and puring down the road like a quire on a perfect note. but only finishing half a car behind???
THIS HAS ME PUZZLED! i understand his only got .1 of a litre more but one extra turbo and probbably 15,000 dollars more for roughly .500 of a second quicker. i dont no, it was roughly 200 meters was he just playing or was it seriously close maybe another 200 meters and would i have prefered to be walking???
this has NOT changed my mind of course i still want one but maybe not for the power anymore!
any thoughts would be great!!!
https://www.sau.com.au/forums/topic/22326-gts-t-or-gtr/
Remember the driver is a factor too.
Take yesterday for example - Gerald's R34 is stock - and there was no-way in hell I could keep up with him.
Why? He's a better driver. Simple.
So... perhaps your GTR driver was taking it easy, perhaps he's juts not that quick on gear changes...
GTRs are very fast when in the right hands - just ask Jet :)
https://www.sau.com.au/forums/topic/22326-gts-t-or-gtr/#findComment-478900
isnt straight line what we r talking about????
why does every one say.. " but prob only in a striaght line "
i dont understand this
when have you ever had a lil run with some one and ended up turning corners .. i dont know about us but ive never done a 2 fast and 2 furios job cause personally i think its stupid and more dangerious then straight line... i had the exact same arguement with a guy in an integra... he goes.. yeh u can beat me straight line but what about corners?? wtf?? when do u ever take corners at 80 90 ks on da road and how often do u go onb da track.... plus considering most . if not all 10 sec cars and under are all rear wheel drives anways...... who cares about corners...
https://www.sau.com.au/forums/topic/22326-gts-t-or-gtr/#findComment-480796
Its not like you can't drive a RWD hard into corners either :) you just gotta choose a different line and shoot out the other side. It just takes a bit more thought and control that's all. The gts-t skylines (esp the 33) aren't that well balanced for a RWD setup as some.
I think the key is a 4WD is pretty much idiot proof where as a RWD it is less so... a lot of track cars are all RWD as well. You don't notice F1 cars being 4WD do you?? lol.
You give one unexperienced driver a FWD and another a RWD, and the FWD will be better around corners... Anyway, Honda drivers.. pft..
https://www.sau.com.au/forums/topic/22326-gts-t-or-gtr/#findComment-480840
Mnay people have run real low thirteens (13.02) and even into the 12's with a standard GTR. Stock for stock the GTR will be considerably faster.
And for the record there is a lot more too All Wheel drive than just being idiot proof. With an experienced/knowledable they will get far more out of a car with All Wheel Drive than a rear wheel drive car as it allows the driver to get more power too the ground at any one time as well as allowing the driver to get on the power far earlier into the corner and too do it with more gusto. Of course you can get a 2wd car around corners quick but it is a different league in regards AWD. Some AWD car have excessive understeer as they turn into a corner and push through when pushed too hard. The GTR does not suffer this but can have excessive oversteer but small mods can alter this to make the car extremely neutral in it handling when combined with the traction that AWD provides it is hard to beat when really pushing through the twisty stuff.
Mick.
https://www.sau.com.au/forums/topic/22326-gts-t-or-gtr/#findComment-482051
    • No worries, everything worked out in the end. I just wanted to make the point that it doesn't matter where it comes from (I.E Australia), it can be broken or improperly built. I would still purchase from these companies in the future. B2R - Not certain how that finished, this was on a car I wired a few things and street tuned. I know the owner ended up shipping the motor back to Australia for investigation. Hopefully some of it is covered under warranty.  Turbosmart - I always pressure test everything that goes on my car. It's a habit from my career in oil and gas. I run two 40mm's and both had major leaks from the actuator to exhaust portion through the shaft. I returned both, they shipped me back two and one was leaking and the other had a 38mm top (40mm gate with 38mm actuator cap, no idea how that happens). Eventually after a lot of back and forth I found myself with two non-leaking gates. I believe this happens a lot more then people would like to believe but you would never know if you don't pressure test them prior to installation. Crank Motorsport - Issued a full refund and let me keep the seat rails. I turned them into scrap metal for other projects. GKTech - Shipped me out a replacement and asked that I modify it as per my idea and that they would do the same for a future revision. ATP - Can just needed a large shim to bolt up properly.  Haltech - They started an actual proper Beta channel for firmware's a few months back and stopped using the general public for testing. I'm now much happier.  Speedtek - f**k Speedtek. I would love to watch them burn.
    • I've got a Turbosmart wastegate, ATP catch can, many GK Tech parts and Haltech everything. Everything's been perfect, sorry to hear your experience wasn't the same
    • The only high-power RB I've personally seen go pop after running for all of an hour on a dyno was built by B2R, while being remotely tuned by B2R. The only wastegates I've ever had leak like a sieve, return, still leak, return and get shipped back the wrong ones were from Turbosmart. The only final drive that I've ever purchased that were unusable, twice... were from Speedtek. The only seat mounts that I've ever purchased that placed the seats in the door frame were from Crank Motorsport. The only poorly designed parts that I had the manufacturer confirm should have been designed as per what I mentioned were from GKTech. The only ECU I've had firmware updates consistently break things are Haltech. The only catch can I've purchased that didn't fit in its advertised spot was from ATP. So forth and so on... Moral of the story, doesn't matter where it's from. Do your research beforehand and stick with products and companies you've trusted in the past.    @joshuaho96 If you want it done right, do it yourself.
    • Something coarse-ish. 180 is good.
    • I was surprised to see all the quick Jack models at the same prices on there. But yeah, grabbing one at 20% off would be great.
