  • Replies 104
This event is now open to NON MEMBERS.
Please keep in mind, NON MEMBERS are not eligible for trophies.
Trophies will be handed over upon seeing your membership card. Please make sure you bring it with you.
Cheers
Brad
Yeah Brad I'll be there as Part of the Tenagah Crew in the Evo.Looking forward too it.Let me know if you want me to muster anyone else up for this.
Cheers for you and Tenegah for coming on board and supporting this event! We are happy to have you guys join in with us.
If you can find more people to come along then please by all means go for it!
We have 8 spots filled and realisticly i need them filled by the end of this week.
Glenn, if you want to bring out the lancer and show some of these boys you dont need 500hp and 4wd to have some fun and be competitive, then feel free to come along! Send me a PM and ill forward the payment details :glare:
Brendon, PM replied to. Very sorry it took me this long to get back to you but have had several commitments lately that have restricted my "forums time" lol
Payment sent. See y'all on the 10th
I haven't beaten any Skylines since the last Wanneroo Track Night :sick:
What are we doing about scrutineering? AHG style with random checks?
Fire extinguishers required?
Edited by Spektor
Paul, would be good to have your skyline there to see if the changes i am making to your car this week work out. If you dont drive it, i will LOL
Ill be over your place sometime this weekend to pick up $$.
Drive the skyline Paul. I want to hear the external wastegate again :cool: *drools*
Hopefully if we get enough work done to it over the next week it will be able to race....cant race it at moment :P
Is anyone else having hassles getting their license out of AASA??
PM me hints on how to do it, coz they are ignoring me, and it just wouldn't be right to deny my adoring public the chance to see
TEH FURY PWN J00 ALLL!!!!!!!!!!!!ONE!!!TY
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
