  • Replies 67
Posted Images
i got screwed with my new highmount turbo set up the mechanic i took it to stuffed it real good he made his own gasket out of some crap which looked like paper and went every where in my motor, he used the wrong boltz which melted on my head i had to spend well over 1500 dollars to get his mistake fixed not bloody happy never going back to him. its hard to find some one to do your car down in here in tassie
^^ you already know the answer :)
Correct.....that's 2 of us now that have been shafted by that mob......and the only reason I went there in the first place is cause he used to be a so called mate.
I used to work on my Rex in his workshop many years ago and drink beer with him all day, now you can't put 1 foot in his workshop.
I've kept quiet for the last couple of months but obviously its time for my rant because he's burning others as well.
Having a Dyno doesn't make you a tuner. When a car is belting out that much black smoke out of the exh that you cant see the car in the workshop, you stop revving the shit out of it (hoping that it'll clear up eventually) and check your settings on the PFC.......try changing the injector values and latencys to accept the bigger injectors and maybe select the correct AFM values.
When a lower hose blows off the intercooler 4 times, you don't keep tightening it up with bigger clamps until it crushes the alloy pipe, you cut off your crooked pipe and re-weld it back on straight.
When an exhaust comes in with no rattles and leaves the workshop banging against the fuel tank and leaking through a hole in the brand new Cat, you do the job again, properly.
No clamps or ties on vacuum lines, fuel regulator squirting petrol all over the engine bay, I had to tell him how to re-route the fuel line onto the different bigger fuel rail, his old man kept bashing iridium plugs against a steel bench to reduce the gap but ended up squashing all of them then levered a screwdriver against the very fine wire electrode of the iridium (absolute NO NO on iridiums, you never touch the electrode, $150 plugs) until I jumped in again and told him how to do it..........I had to baby sit these guys when I should've found someone with a hoist and mig and done it myself.
But to add salt to injury, he quoted me $1000 for all the bolt on work and 1 day to do it (Shaun at Boostworks was a similar price, maybe a tad dearer). It took 3 days to do the job and when I went to pick it up the price doubled to $2000. He said that nothing was straight forward (derrrrr, is this the 1st GTR he's done) and that I couldn't take the car away until I paid him.
I'm really tempted to get legal with this guy and serve him personally then drag him before a small claims magistrate (up to $5000 without lawyers).
is this bloke a fellow brother :) then no let it be if he isnt then pursue the matter further if your feel that is needed otherwise you have to try and live with the fact that you chose a mate over Shaun
i know that isnt a definitive answer but i think you know what needs to be done
Like I said earlier, I have kept quiet about this for awhile now and have paid various other workshops to fix his stuff ups.
i used to be mates with the business owner of this mentioned "tuner"
when they where at the old shop, seemed like a good bloke, but then again, he was only doing a zorst on my VT.
would never take my line there, not after what adam told me.
This is why I do alot of my own work.
I have the knowledge and the tools. My old man was the head mechanic on the Datsun rally team in the 70s and avid motorcycle racer. My uncle a drag racer. I'd like to think I've been brought up right around mad-scientist-machinery. I know a ring spanner from a blow torch, so I do my own work when I can't trust anyone with my ride.
Yeah me too, I have a full workshop of tools that were gathered over almost 20 years of work at Adelaide Engine Service. So I too can build a bike or car from scratch but because I work so much these days, I don't have the time to do any major work (bike was built during 'graveyard shifts') and being self employed it costs me more to take time off work than to pay someone else to do the work.........I still don't like being shafted though!!
    • Given it is temporary, I bought a  cheapy gauge mount (which has become enflattened) which I will screw into the existing phone mount Also a first for me; given this is a temporary install I could not think of any reason not to use one of those "add a fuse" thingies to source the battery and IGN power. I had always figured they were pretty dodgy but having a good look at them I think they are a valid option for sourcing power from an existing source without cutting
    • Finally for now, a bit more work on the transmission temp gauge. I was wondering how Raceworks do a gauge for $100 that autometer want $500 for. No idea about the accuracy of course, but they have cut a few corners that made things hard.  First one I mentioned above, the sender is physically difficult to fit and doesn't work with their own adapters (the extra fittings I used to get the sender into a hose cost more than the whole gauge, lucky I had stuff in the shed) Second, the temp sender wires are way too short. They are shown as 2.7m on the box and I know my routing was long from navigator headlight to driver's firewall back to centre console, but I had to lengthen them by about 2m total - 2 joins in each wire. Also, same with the supplied power loom, they needed about an extra 1m to get the fuse box where I sourced power. Another join in each wire since one end wasn't supplied terminated. I know they could argue that the wires might be long enough depending on situation, but when you consider parts and particularly labour, it would be a very expensive cheap gauge if you can't do the work yourself. And, only a small issue....but it would have been nice if they remembered to tap a tread onto *both* spacers they supplied for the bracket....I haven't had to use the M4 tap often!
    • If it does get a turbo it would blow the JCW Mini out of the water considering how "close" some of the tests were. Then again the Mini would probably get one of them Stage 69 tunes.
    • Next up, the extinguisher is mounted but really only temporary because I ran into clearance problems (the bracket fit fine....until I put an extinguisher on it). It picks up the seat bolt mounts but has long bolts running through 20mm spacers for now Doing it properly requires a bit of quick welding but I ran out of time, this will do for the practice day
    • Family events weekend but a snuck a couple of things in. NSW state champs were down at Wakefield so I got Gordon Leven's to bring some A052s down in the right size for some spare rims I had that "fit" (actually ex-Leaf Nismo.Rays in 18x7.5). Tyres are 235/45/18 so they are narrower than stock (19x8.5s) but I need to keep road tyres on it for daily use for now. In a first, those weird size tyres had been in the yoko warehouse for so long (4.5 years apparently) that they offered 4 for the price of 2....so 4 practice tyres for about $1100. Bit of a bargain for sticker tyres, considering the real purpose of the practice day is mostly to see how the various temps go (and the weather is due to help, forecast 32o). In terms of race wheels, it looks like I should be able to fit 9.5 fronts and 10.5 rears but 18 vs 19 height will be based on what tyres I can get in the right size - good tyres are very limited in available widths in diameters above 17" so some planning is needed. Once I'm sure this car will work I'll order a set of custom BC wheels like I did for the R32, you can get exactly the right width and offset to make the most of the available space in the wheel well (the 32 has 295s all round on 18x10s and they are awesome) Incidentally A052 are asymmetrical but not directional which is good news for rally use if the front and rear wheel sizes are different because I can swap them side to side on the same axle. Directional tyres are a nightmare with staggered size wheels because each tyre is fixed on that corner unless you can get it rotated on the rim (not really practical mid rally in most cases)
