I don't know what you mean by "the actual box of the seat belt..." ....
Perhaps posts some pics... if it's pulled all the way out, check for knots or anything that's preventing it from retracting... otherwise, the retracting mechanism inside the perhaps is stuffed?
Never done it myself, but if all of the above fails - open up the box where possible to see what's going on.
https://www.sau.com.au/forums/topic/223301-seatbelt-hassle/#findComment-3934115
yes its pulled all the way out , and it isnt retracting, yeah thats what i mean the mechanism inside could be stuffed and i was wondering how i could get into that to check it out.
how do i get into that part do i have to remove the seats or what?
thanks for the help
https://www.sau.com.au/forums/topic/223301-seatbelt-hassle/#findComment-3938779
im guessing your talking about the fron 2 seatbelts. if so i think the mekanism is inside the pillar, so take off the pillar and it should be bolted up in there, as for the back ones the same applies, cant remember if you need to remove the back seat. removing the pillars is easy, they just hold on by clips. be gentle you cant really go wrong.
https://www.sau.com.au/forums/topic/223301-seatbelt-hassle/#findComment-3954872
If you have an R33, two bolts at the bottom then the bottom section of the seat slides out, you need to pull it a little bit up when you pull it out.
2 more bolts on the top section, this has to be lifted up for it to come out.
https://www.sau.com.au/forums/topic/223301-seatbelt-hassle/#findComment-3960839
    • No. I think it's gone. 😭 I think you can get body coloured ones on eBay so I think I'll get one of those... Or just hang a red ribbon from the hole and whack a TOW sticker next to it.
    • Can't say I've had a bad experience with one on my car, then again it only gets washed once or twice a year... The wheels on the other hand, get a good spray often due to my shitty dusty pads.
    • @MBS206 thats pretty neat and tidy to me!  I'll get a photo of mine when I'm out there next. It might require multiple photos to understand the scale of the atrocities though... In total I have 4 sheds of varying sizes and layouts. Main shed is 14x8, second shed is 3x8, third shed is 11x2.5, fourth shed is around 6x4.  All are pretty much full.   The main goal of my cleaning tsunami is to make the main shed predominantly car and motorbikes only. Second shed is my metal fab room (2 x bench grinders, drill press, bench belt sander, metal band saw, scrap metal storage and some of my garden tools.  3rd shed is more bigger garden stuff, storage for engine crane, jack stands, concrete grinder, concrete mixer, air compressor lives there, and it now has two 2mx2m pallet racking shelves with itemised boxes holding building stuff, electrical stuff, plumbing stuff, etc, etc.  The 4th shed is Ryobi electric ride on mower, mini boom sprayer, ancient Kubota tractor, more garden stuff!  I have got a lot of shit....  Then there's the pool house (8mx4m) and the pool pump shed (4mx4m).  I built all of the sheds over the 11 years we've been here.  The main shed was a Ranbuild kit, the rest are all custom made to fit the areas available. Building the main shed taught me a LOT as I had no idea about building anything prior to that!  I've still got one more in me. It will be my man cave which I poured the extra concrete for way back when I poured the concrete for the main shed. The idea is the Skyline will be a centre piece of the main cave once (if...) it's finished.  I told my now 14 year old son yesterday that I will 100% drive him to his year 10 formal in 2 years. Still a long way off but at least I now have a date to work towards! 🤣
    • Modern oils are amazing. Add tyres to that as well.
    • Probably a smart choice to buy one vs build, purely for the motivation part as you said! Imagine the metal dust everywhere from grinding all the steel to build one. Ha ha ha!   Also, post a photo of your garage.   Mine is below, this is where I've been cleaning and have already half filled a caged 6*4 trailer. And this is after my cleaning expedition mentioned previously... The middle normally has a car in it, but I'm dumping things in the middle as I sort through them. And poor skyline was dusty and has had the lightest few drops of rain and now it looks atrocious and needs to be dragged back out and washed thoroughly! And yes to the right is technically another bay, you really can only see 2 bays out of 3 in this picture.
