Where do you want to relocate it to? If it's the boot, I'm pretty sure there was an Auto Speed article on this, or even one in an old HPI magazine. I would have thought this would only be needed for a major engine swap or hidden wiring of a show engine bay. Either way, you are up for one hell of a task and plenty of hours soldering under the hood :wacko:
And before you ask, that was custom made by a user on this site and I havnt come across anywhere that sells them... what you could do is paint the standard one in a color that suits your engine bay! :P
What are you talking about?
The picture posted is one that I have on my car.
And before you ask, that was custom made by a user on this site and I havnt come across anywhere that sells them... what you could do is paint the standard one in a color that suits your engine bay! :)
er you can buy them on uk ebay :)
we've done alot of hidden wiring in engine bays andto be honest there is no easy way to do it.
we basically just split everything, extend it all and run it all inside the car either under the dash or in the glove box
  • 9 years later...
    • Yeah so N1 and any other larger than factory pump are pretty famous for pumping the sump dry...obviously we don't often get to spend 20 or 30 seconds at high rpm/full noise on the road so I'd still be suspicious that is what is happening here.
    • You are also getting pressure dips on gear shifts. They're just not dipping as far, but they're dipping quite below the amount of oil pressure you should be seeing, for how much RPM drops.   It quite little could be the oil pressure relief valve is starting to stick open a little/is slow to close.
    • Can you log battery voltage, and TPS, and put all four of those into a single image (even as split graphs)?   The oil pressure drops aren't following RPM as such. I'm intrigued if you may have a ground loop between different sensors. With the engine not running, log your sensors and for example cycle the throttle pedal. See if any sensor values flutter or move about. This won't be a perfect test either as the ECU won't be cycling all of its actuators like it would be while running. What EMTRON do you have? Do you have a link to the wiring guide for that ECU?
    • What logic functions do you feel are missing from the Haltech that others have? Is there a limit to how much logic you can string together? By limit, I mean it's like only a single level or two levels of Boolean logic. Realistically, AND, OR, and NOT, is really the only logic you need and realistically, you can also do away with another logic gate of the three above . With those three you can build the full functionality of any Boolean logic you want.
    • Well that rules out the relocation theory, however with no load, you're still getting 1.5bar of oil pressure. Can you present that data in a scatter graph over longer period? Would really highly the anomalies. Wish Haltech could do that.
