I have an R33 GTST but I figure this question would relate to any model, I am wondering what the effects would be (good/bad/if any) from putting an aftermarket intercooler in whilst leaving the stock turbo installed. I understand that there is no real need, this just came up in conversation the other day and I'd like someone to clarify it for me.
Thanks,
Ive installed one while running stock boost.
I didnt notice anything bad. Ive tested it with my Apexi RSM + Gsensor, and it stills runs very similar times.
However i did notice it slightly change the sound of my blitz BOV.
The reason why i installed it was because i am a uni student, so most of my mods i do on my car have to come in stages due to money restrictions!!
Next few mods will be HD clutch, then onto boost controller/SAFC2 i think! Then off for tune! So the bigger FMIC will be used!
But to answer your questions, in my experience, I didnt notice any negative effects.
Same here I am going stage by stage, so i figure once I have finished replacing things like belts, water pump, thermostat etc i'll worry about additions like an intercooler.
Thats another thing I probabley dont need to do things like replace the thermostat but I am for the simple fact I will know its new and works perfectly.
Edited by Nimmo
cooler air hitting your engine, longer engine life, better combustion, better performance on hot days, but slightly more lag
go for a drive, feel the output pipe of your stock cooler, not that cold
find a mate with an aftermarket one, go for a drive, see how much colder it is?
Thanks guys for your input that clariflys everything for me, one other thing joeyjoejoejuniorshabadoo you say not too big I seen many that say they are made for R33's so I guess these are an appropriate size then yeah?.
I also own a 33t... I also have more mods than this but I had the stock turbo with an FMIC and I can tell you there was most certainly a difference. Not one I would assume you would find on a road often but it's possible in an extreme ambient heat you would notice. Though depending on the sizing of the inter cooler you may notice similar issues I did. I have some rather good piping courtesy a shop I am not allowed to mention but if you were to searh posts would find >:P.
Basically I had better response.. infinetly better.. this is due to the fact my inter cooler is not the 3" thick 2x2m monstrosity most have. but you will not find it in a shop.. its a rather limited inter cooler solution which was custom made for someone else who I bought it off. The biggest noticeable difference was on a track my car didn't over heat in 10 seconds but instead gave me the opportunity to find out what else overheats when running wife open for long periods of time. When coupled with a good exhaust the response goes through the roof, coupled with a mammoth inter cooler I would expect the opposite effect on response but equal cooling characteristics.
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
