talk to me.
i am doing mine atm.....well nearly finished now.
you will need. and electrician and mech.
you will need.
rb25 loom (electrician required) dont try to work it out if you havent done it before.
rb25det. rb20 box bolts straight up.
will need , and i still need info on speedo cable if you are going rb25 box
if you are using a 25 box you dont, i repeat dont need to change the length of the tail shaft only the yoke on the end needs changing to the rb25 one...got mine done for about 150-200 i think.
depending on other mods eg forward facing plenum, that is all that you really need to change...oh and you might need an r33 accel cable. there are alot of other space plugs on the rb25 loom that arent used as well, but that doesnt matter...if you want more details pm me, and i will right a full document.
peace.
220rwkw?
for the $5K you have to spend, you could make a reliable 250rwkw out of the RB20.
without the hassles of rego paper work, engine swap, being off the road for ages etc.
to make 220rwkw out of an RB25 you are going to need upgraded....
intercooler, fuel pump, afm, injectors, turbo, exhaust, ecu, tune
now, if you buy the above parts for the RB20 you already have, you will still make over 220rwkw and not have to fork out for the purchase of RB25, gearbox, tailshaft, engine swap costs.
If your goal was on the crazy side of 250rwkw, i'd understand the need for more capacity.
just a thought mate.
I think spending the cash on the rb20 will yeald good results for less money.
have a look in to the RB20 dyno results thread in the forced induction section to see what mods make what power on peoples cars.
eh i will be looking for more then 220rwkw on stock injectors in mine...should be able to. turbo maybe, ecu yes you will, afm...yeah maybe, fuel pump might as well do it.
Yeah i have have been looking at the dyno results for RB20s with upgraded bits. What im unsure about is the torque low down. Everyone is saying how much more power the RB25 makes over a 20, I had a 33 GTST with a bit of work done it was decent. But if a RB20 will make the power im chasing maybe thats the best way to go.
Will i still need a 33 box to handle the power>??
rb20 box should handle 260 ish....but wont be on it.
if you have a rb20 already stay with it seriously...i should have, this conversion has cost alot. just make sure you do it properly...if you are aiming for 240+ then i would considering rebuilding it internally, dont take no chance. and yes the power in a 20 will come alot higher in the revs then a 25. so it depends on what you want.
Depending when you plan to do the conversion, I can offer to do a plug'n'play loom for you. Send me the RB20 and Rb25 looms and I will return it ready to simply plug in and go. I wire up all items to ensure complete functionality of the standard RB25 ECU (eg. boost solenoid, VCT, FICD, A/C etc). I normally charge $300 for a series 1 or 2 RB25 or RB26.
I have personally done the RB25 into R32 conversion twice and can recommend it. The RB25 gearbox will require more work and if you already have a manual R32 you will need to either modify the gearbox crossmember or make a new one. If the car was originally auto and you plan to use the RB25 gearbox, from what I have seen the original crossmember should bolt up ok.
Cheers
correct..i have an auto from factory and the rb25 box went straight in.
