Enkei Gtr Hollow Spoke Light Weight Wheels 18x10+20
After some inspection it seems that the diff has a metal gear near the diff flange with the sensor slotting in a hole that hovers above it. I believe it is some sorta Hall effect sensor which reads the amount of rotations of the pinion to calculate the cars speed. the 350z also uses this mechanism on the diff except it has it on either one of the diff flangers and 2 seperate speed sensors. I soldered the wires and i still have no reading. might just go with the gps speedo at this stage haha
update i did some test and think the diff has a 3.3 ratio i also took it out and readjusted the offset bushing on the subframe which made the diff sit higher about the same as the stock r200 r34 diff. (P.S : you'll need an 18mm spacer fabricated from your driveshaft to diff flange as there is a gap i think it might be unnecessary for some skylines I have a HR34 which is also a 4speed automatic which is now slower with the smaller ratio as the OG ratio is 3.9. ill see whether or not ill change the ratio after i do my manual swap. I am putting in a RB20det gearbox in it honestly hoping the gearing will be better if not ill probably steal a crown and pinion from a g37 or some with the 3.9 ratio
No. It only typically does it when thrashed (ie on the track), or if it is overfilled, or if there is some other problem in the PS system.
Is that a design fault by Nissan then?
