Can you tell me how long my piece of string should be?
motor condition, type of use/abuse all move the goal posts. Why would you want to anyway, a stock R33 has no real power in the top end anyway.
Cos, you could R+D it and then tell everyone how long it lasted............
personally if it were my 25 I would not be revving it past 6500, but it's your engine so up to you. sure it will survive 7000 a few times, hell it could survive 8,000 a few times... but for how long?
lol, this is a thread full of comedians.
Find out where the power peaks and drops off, and set the rev limit there.
If your peak power is beyond 7,000rpm, then you have a massive turbo that requires a built engine anyway.
Your shift point shouldn't be at peak power, it should be where you have got an optimal area under the curve. I aim for ~500rpm after peak power...
the idea of rev limiters and tachometer shift lights go hand in hand, when you change gears you want the engine rpm to fall back right into the middle of the power/torque area when the motor is just at its peak power levels...(where the hp and trq curves meet/intersect or are closest to each other...within reason of course)
for example the dyno sheet below for my gts4
the sweet spot is 5150rpm, theoretically i would want the engine rpms when changing up to drop back to anywhere between
4200 and 5300 rpm.
for example if a rb engine bolted to a manual box drops 1100 rpm between 2nd gear to 3rd gear the ideal shift time would be 5000 to 5500 rpm
to get the maximum amount of power when accelerating. this is a rb3026det freshly rebuilt for drift, mildly tuned @8psi so there's not really any call to go over 7000 rpm, and even then you only want to go past 6000 once in top gear.
Edited by nizmonut
question
can the stock engine rev past 7,000 rpm safely??
-stock internals, stock airflow etc
- and assuming your not limited
More to the point - stock airflow (which one assumes is turbo/IC and so on)
Absolutely useless and pointless
Either way, luck of the draw over the limit, might last a while, might last a bit longer, might not
Simple really.
One of my first Power FC tunes on the highflow turbo i had,the rev limit was set at 7500rpm.
Was like this for about 8 months and saw 7500rpm a number of times,though was not held there for any more than about 3 secs.
    • Reading your posts Josh, sometimes I feel like I've gone in a time machine back to the 90's when everyone was doe-eyed and figuring things out for the first time.  I've lost track of how many single turbo GTR's I've seen on track that haven't burnt down lol. Everything has been figured out a long time ago. These things are at the point now where its essentially turn-key to go single turbo.
    • Among other things yes. Making sure to either use an oil pressure regulator or the right restrictor size for your oil pump/range of oil viscosities you intend to run, making sure you plumb the lines correctly, turbo should be placed such that it siphons properly even when the water pump isn't turning so you don't boil coolant in the turbo after shutdown, oil return should be low resistance and also preferably picking the one that is most likely to return to the pickup as opposed to some other irrelevant part of the pan. It's far from impossible to figure this out but I have seen people really, really struggle and if that's the case it's easier to just take the path of least resistance. To me, bolt-on twin turbos are a fixed cost whereas single turbo is almost unbounded.
    • Latest round of updates on the car. I purchased and installed a SWS clutch slipper to help with 60ft times and got some second-hand good condition 275/40R17 Hoosier DR2 radials. Test and tune in November showed the tyres were an upgrade over my over 15 year old mickey Thompson's and I got a 1.8 second 60ft and pb et of 11.71 but even then, that run wasn't great due to rain and driver error (the event got called off 10 minutes later fast forward to the weekend just gone 25th of Jan and there was finally a break in the weather to let racing happen. The first run the track was slippery and only managed a 12.1@129 Second run the track was better and got a new pb et and mph: 11.54@131   Lith and I then worked out that I installed the previously mentioned clutch slipper incorrectly and its never been working, and I had just been dumping the clutch the entire time, we also noticed it was on street boost and not race boost. So I lined up for a third run with the car turned up in the first two gears, but the passengers side axle objected to clutch dumps and left the chat which stopped my weekend.   so there will be another attempt in the future once I replace the tyres as they rubbed and are stuffed now. but a low 11 should be on the cards.
    • Ceramic coating and heat shielding, you mean?
    • Turbos don't require pulling the motor apart so that's "easier". I would recommend the Nismo R3 turbos instead if you want to do stock twin turbo. It doesn't make as much power as the 2530s but it's only like ~50 whp off the mark and should have better response (ball bearing CHRA, slightly smaller turbo). A local that went with a Garrett G30 and 6boost manifold recently nearly burned his car to the ground after the hood insulator started melting and and burning so if you go single turbo I recommend doing a lot of research and validation work to make sure you don't do the same.
