Can you tell me how long my piece of string should be?
motor condition, type of use/abuse all move the goal posts. Why would you want to anyway, a stock R33 has no real power in the top end anyway.
Cos, you could R+D it and then tell everyone how long it lasted............
personally if it were my 25 I would not be revving it past 6500, but it's your engine so up to you. sure it will survive 7000 a few times, hell it could survive 8,000 a few times... but for how long?
lol, this is a thread full of comedians.
Find out where the power peaks and drops off, and set the rev limit there.
If your peak power is beyond 7,000rpm, then you have a massive turbo that requires a built engine anyway.
Your shift point shouldn't be at peak power, it should be where you have got an optimal area under the curve. I aim for ~500rpm after peak power...
the idea of rev limiters and tachometer shift lights go hand in hand, when you change gears you want the engine rpm to fall back right into the middle of the power/torque area when the motor is just at its peak power levels...(where the hp and trq curves meet/intersect or are closest to each other...within reason of course)
for example the dyno sheet below for my gts4
the sweet spot is 5150rpm, theoretically i would want the engine rpms when changing up to drop back to anywhere between
4200 and 5300 rpm.
for example if a rb engine bolted to a manual box drops 1100 rpm between 2nd gear to 3rd gear the ideal shift time would be 5000 to 5500 rpm
to get the maximum amount of power when accelerating. this is a rb3026det freshly rebuilt for drift, mildly tuned @8psi so there's not really any call to go over 7000 rpm, and even then you only want to go past 6000 once in top gear.
Edited by nizmonut
question
can the stock engine rev past 7,000 rpm safely??
-stock internals, stock airflow etc
- and assuming your not limited
More to the point - stock airflow (which one assumes is turbo/IC and so on)
Absolutely useless and pointless
Either way, luck of the draw over the limit, might last a while, might last a bit longer, might not
Simple really.
One of my first Power FC tunes on the highflow turbo i had,the rev limit was set at 7500rpm.
Was like this for about 8 months and saw 7500rpm a number of times,though was not held there for any more than about 3 secs.
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
    • Awesome writeup and details. Thanks for sharing the story so far. I can relate to parts of it with my previous car and some of the issues I had to deal with.
    • Wow the colour matched hard top completely transforms the car. Are there any nice front lip options for the car or is that off the table?
    • Generally yes but for some reason I've been ruthless this time around!  I might even need to do another tip run after the way I've finally been able to hit the delete button on shit I've stepped over, stepped around and tripped over for the past 10 years!
    • I just quote the Rolling Stones. Paint it black.
