LS1s are a great combo for a R32... just make sure you add a pair of huffers on the side :blink:
yea that's what i was thinking.. i know the ls1 has nice low down torque and would slide nice also but i'd love to go twin turbo ls1 but the kits are in excess of $10k... ill have all the time in the world as i'm losing my license for a while. what would be the approx cost of the ls1 build.. from an r32 NA auto + ls1 + 6spd + custom fabs for the mounts and such?
i got a gen3 with 6speed..
i had a r32...
so many workshops turned me down big name shops, cause they told me balance of car would be way out..
i had a budget of 20k as i already own the gen3, i no alot of stupid money but it was a project and i allowed at least 8k for just front end setup, and still alot of workshops turned me down..
i was very disapointed and it turned me off..
they all reckon the s15 or 14 silvia with the gen3 in it is so far off balance its a miracle it can drift the way it does..lol jelousy now i think about it....
do it man it would be an absolute street weapon, and with turn a whole freeway up in smoke at 120km's
yer but honestly i cant sit there an argue with a workshop owner and end up leaving my pride and joy in there hands, its like im forcing them to do something there jelous of..
kunts, but if your good on the tools and you do have the time, i say do it, but once you start to look into it, you cant spare any cash on the front end setup..
i cant find any pics of the silvia gen3, but it showed the whole front setup an fabrication, its like a work of art..
if only i had the time, i realy cant stay up till 12, 1 in the morning these days my day time job is to demanding, lol but f*k im thinking about it once again...
haha yea it's like that ay.. i work 7 days a week atm and it's a struggle!
I've just been watching vids and there a bloke called mikespeed with a blown ls1 s13 and it's farking nuts!!! but then i'd also love to just build a really solid rb and that would be easier.. ahh i dno what to do yet.
how will it effect the balance enough to matter... the weight difference is marginal at best (ls1 lighter than rb)
honestly i only started to research the project after i gave up with wanker workshop owners giving me the bullshit lines.. it got to a stage were i had to bring 6k cash in my hand to show the bastards i wasnt lieing..
but after a bit of research and talkin to a few guys it is possible and if the front end is done properly, you wont have to maintain the thing forever..
but either way big dollars but good results...
What are the costs for a similar setup when one has an ls1 with associated oil leaks, an r33t car, 4 stock 33t turb's working.. no piping work, exhuasts appropriate manifolds, gaskets, lines etc... management....
if you go to the trouble of getting an ls1 into a 33... you may aswell add the stock 33t turbs of the side... a pair of t3's should work nicely for a lower boost mod... internally stock ls1...
I know it's been done.... I would have preffered a savage na 91 ron monster 33 but for 10c more I could have something that eats more money...
seriously though... what costing involved? as a REAL project for someone good with thier hands... modest budget and space available for hte thing to sit there until it is ready for use?
    • When sanding across a convex panel, you need to sand, as much as possible, at right angles to the curve. If the panel is compound convex curved (ie curved in both directions) then you are SOL and have to use "craftsmanship" to get it right.
    • Today in Skyline arts and crafts!! I鈥檝e made some progress.    had to put extra notes in there so I don鈥檛 stuff it up 馃槀
    • This sounds like me. And then why I leave shit that I had previously hobbled together broken. Lately I've changed strategies to "If I don't want to justify the money on decent stuff, I'm not going to justify hobbling it together". I'm still for DIY, but DIY it properly is more my thing. However, I am terrible on not setting up backups still... Which reminds me, I need to go backup some of my work VM machines... Oh, it's also why I've become a lover of building things into Docker Containers... Then I just need a machine that can run docker, and bam, that specific system is up and running, on the specific versions of everything I need for it to run (In the event a change in required software version breaks something else). Also, these days, my steep learning curves are spent with work related stuff, and on very varied projects, that my want to do other random projects like build a dashboard for my own car has dwindled away to "I just want the car running", which is my current PITA, as I'm getting the Landcruiser usable again, and it has just been non-stop the past 6 to 8 weeks of buying parts, and working on it. Oh, and tools that are meant to be fit for purpose... And they break, because 25 year old 4WD decides it's stronger... But by the time I have it ready to roll back out the drive way, nearly all the stuff in it will have been touched and serviced, so the damn thing better give me NO FREAKING ISSUES, for at least the next 50,000KMs! Just redone whole front of the motor, and resealed the up top stuff, replaced a bunch of things getting perished, new timing belt done, water pump, lower timing cover (Toyota diesel engine runs timing GEARS for the bottom half the motor, and a timing belt from halfway up to the top), new harmonic balancer, fix up the alternator, new thermostat, full swivel hub rebuild, new bearings and seals front and back, steering box rebuild, new battery, and today, it turns out a rear shock has let go, so four new shocks are about to go on order, and that will leave me with after the next run of work, to see if I need to order just a brake caliper re-seal, or if I'll need new pistons in them too. Oh, and I'll finish welding in the new floor sheet metal shortly too. Presently I just want it finished already... But once all the above is done, I still need to fully service diffs, gearbox, transfer, and motor. Then flush and bleed the clutch, and flush and bleed the brakes. But enough about our waffle, back to Duncan's heat problems... I think for Duncan he just gets a thermoswitch, and a manual switch to run some water misters. Thermo so it's only on above certain temps, and the manual switch so it can be turned off even if it is above certain temperatures. IE, switch on for "I'm now on track", then it doesn't need any "smart" computers that might try and do things wrong. And switch the thing off completely on the cool down lap, so when he stops in pits, there's not even a possibility of it dripping any water out to get him in trouble.
    • So I ran into the same problem. I got stuck in the cycle of again of putting putty sanding it, putting putty sanding it, because of a low spot. And notice my block is not completely flat with the panel, even though it's a long block. My panel is slightly curved. Is this an issue? Do I need something that matches the door perfectly, or no?    I do have the smaller flexible block that covers the width of the repair just not the length, I was experimenting with it again to but seems to be the same issue
