LS1s are a great combo for a R32... just make sure you add a pair of huffers on the side :blink:
yea that's what i was thinking.. i know the ls1 has nice low down torque and would slide nice also but i'd love to go twin turbo ls1 but the kits are in excess of $10k... ill have all the time in the world as i'm losing my license for a while. what would be the approx cost of the ls1 build.. from an r32 NA auto + ls1 + 6spd + custom fabs for the mounts and such?
i got a gen3 with 6speed..
i had a r32...
so many workshops turned me down big name shops, cause they told me balance of car would be way out..
i had a budget of 20k as i already own the gen3, i no alot of stupid money but it was a project and i allowed at least 8k for just front end setup, and still alot of workshops turned me down..
i was very disapointed and it turned me off..
they all reckon the s15 or 14 silvia with the gen3 in it is so far off balance its a miracle it can drift the way it does..lol jelousy now i think about it....
do it man it would be an absolute street weapon, and with turn a whole freeway up in smoke at 120km's
yer but honestly i cant sit there an argue with a workshop owner and end up leaving my pride and joy in there hands, its like im forcing them to do something there jelous of..
kunts, but if your good on the tools and you do have the time, i say do it, but once you start to look into it, you cant spare any cash on the front end setup..
i cant find any pics of the silvia gen3, but it showed the whole front setup an fabrication, its like a work of art..
if only i had the time, i realy cant stay up till 12, 1 in the morning these days my day time job is to demanding, lol but f*k im thinking about it once again...
haha yea it's like that ay.. i work 7 days a week atm and it's a struggle!
I've just been watching vids and there a bloke called mikespeed with a blown ls1 s13 and it's farking nuts!!! but then i'd also love to just build a really solid rb and that would be easier.. ahh i dno what to do yet.
how will it effect the balance enough to matter... the weight difference is marginal at best (ls1 lighter than rb)
honestly i only started to research the project after i gave up with wanker workshop owners giving me the bullshit lines.. it got to a stage were i had to bring 6k cash in my hand to show the bastards i wasnt lieing..
but after a bit of research and talkin to a few guys it is possible and if the front end is done properly, you wont have to maintain the thing forever..
but either way big dollars but good results...
What are the costs for a similar setup when one has an ls1 with associated oil leaks, an r33t car, 4 stock 33t turb's working.. no piping work, exhuasts appropriate manifolds, gaskets, lines etc... management....
if you go to the trouble of getting an ls1 into a 33... you may aswell add the stock 33t turbs of the side... a pair of t3's should work nicely for a lower boost mod... internally stock ls1...
I know it's been done.... I would have preffered a savage na 91 ron monster 33 but for 10c more I could have something that eats more money...
seriously though... what costing involved? as a REAL project for someone good with thier hands... modest budget and space available for hte thing to sit there until it is ready for use?
    • Well, after the full circus this week (new gearbag, 14 psi actuator on, injectors and AFM upgraded, and.....turbo repair) the diagnosis on the wastegate is in. It was broken. It was broken in a really strange way. The weld that holds the lever arm onto the wastegate flapper shaft broke. Broke completely, but broke in such a way that it could go back together in the "correct" position, or it could rearrange itself somewhere else along the fracture plane and sit with the flapper not parallel to the lever. So, who knows how and when exactly what happened? No-one will ever know. Was it broken like this the first time it spat the circlip and wedged itself deep into the dump? Or was it only broken when I tried to pry it back into place? (I didn't try that hard, but who knows?). Or did it break first? Or did it break between the first and second event of wierdness? Meh. It doesn't matter now. It is welded back together. And it is now held closed by a 14 psi actuator, so...the car has been tuned with the supporting mods (and the order of operations there is that the supporting mods and dyno needed to be able to be done first before adding boost, because it was pinging on <<14 psi with the new turbo with only a 6 psi actuator). And then tuned up a bit, and with the boost controller turned off throughout that process. So it was only running WG pressure and so only hit about 15-16 psi. The turbo is still ever so slightly lazier than might be preferred - like it is still a bit on the big side for the engine. I haven't tested it on the road properly in any way - just driven it around in traffic for a half hour or so. But it is like chalk and cheese compared to what it was. Between dyno numbers and driving feedback: It makes 100 kW at 3k rpm, which is OK, could be better. That's stock 2JZ territory, or RB20 with G series 550. It actually starts building boost from 2k, which is certainly better than it did recently (with all the WG flapper bullshit). Although it's hard to remember what it was like prior to all that - it certainly seems much, much better. And that makes sense, given the WG was probably starting to blow open at anything above about 3 psi anyway (with the 6 psi actuator). It doesn't really get to "full boost" (say 16 psi) until >>4k rpm. I am hopeful that this is a feature of the lack of boost controller keeping boost pressure off the actuator, because it was turned off for the dyno and off for the drives afterward. There's more to be found here, I'm sure. It made 230 rwkW at not a lot more than 6k and held it to over 7k, so there seems to be plenty of potential to get it up to 250-260rwkW with 18 psi or so, which would be a decent effort, considering the stock sized turbo inlet pipework and AFM, and the return flow cooler. According to Tao, those things should definitely put a bit of a limit on it by that sort of number. I must stress that I have not opened the throttle 100% on the road yet - well, at least not 100% and allowed it to wind all the way up. It'll have to wait until some reasonable opportunity. I'm quite looking forward to that - it feels massively better than it has in a loooong time. It's back to its old self, plus about 20% extra powers over the best it ever did before. I'm going to get the boost controller set up to maximise spool and settle at no more than ~17 psi (for now) and then go back on the dyno to see what we can squeeze out of it. There is other interesting news too. I put together a replacement tube to fit the R35 AFM in the stock location. This is the first time the tuner has worked with one, because anyone else he has tuned for has gone from Z32 territory to aftermarket ECU. No-one has ever wanted to stay Nistuned and do what I've done. Anyway, his feedback is that the R35 AFM is super super super responsive. Tiny little changes in throttle position or load turn up immediately as a cell change on the maps. Way, way more responsive than any of the old skool AFMs. Makes it quite diffifult to tune as you have to stay right on top of that so you don't wander off the cell you wanted to tune. But it certainly seems to help with real world throttle response. That's hard to separate from all the other things that changed, but the "pedal feel" is certainly crisp.
    • I'm a bit confused by this post, so I'll address the bit I understand lol.  Use an air compressor and blow away the guide coat sanding residue. All the better if you have a moisture trap for your compressor. You'd want to do this a few times as you sand the area, you wouldn't for example sand the entire area till you think its perfect and then 'confirm' that is it by blowing away the guide coat residue.  Sand the area, blow away the guide coat residue, inspect the panel, back to sanding... rinse and repeat.
    • The detail level is about right for the money they charge for the full kit... AU$21.00 each issue, 110 issues for a total of $2,300 (I mentioned $2.2K in the first post when the exchange rate was better). $20/week is doable... 馃槓
    • If planning on joining us for the day(s) please indicate by filling in this form. https://forms.gle/Ma8Nn4DzYVA8uDHg7
