I need to know what the spline count is on the r32 Gts-t r200 vlsd diff. I bought an s15 HLSD but it did not come with the 30 spline output shafts. I've gotten some info that the r32 GTR output shafts are 30 count on the spline but I need to know if my gts-t ones are as well. I already know that the gts-t has a 13mm ring/pinion unlike the usdm 240sx which most of the guys swap the hsld into. they are the ones having the problems with the output shafts.
if anyone has one lying around from a r32 gts-t can you count the splines on the shaft.
thanks.
https://www.sau.com.au/forums/topic/223413-r200-output-shafts-from-r32-gts-t/
