C'mon you're all a pretty creative bunch
Give me some ideas for my GTR using the top two combinations (sorry, I'm not into paying thousands for plates) to keep it around the $500 mark.
http://www.ppq.com.au/CreateAPlate.aspx
https://www.sau.com.au/forums/topic/223423-httpwwwppqcomaucreateaplateaspx/
I have seen "TI3VOM" and "PMS 247"
How about - 60J1RA "Go ji ra"
The only one which falls into the $400-500 category is PMS247 and I don't think Mark would drive it with those on :banana: btw, its taken
I came up with MYTR. Its not cheap, but: Mightier, MY GTR. Its available, but yeh they reckon about $2300.
GTR320 is available and cheaper too.
Thats all I have.
Edited by datto260Z
I got
280BHP - if you feel like keeping your gtr stock...unless that is too late then forget that...
26LTT - 2.6L twin turbo
ZLA26 - Godzila 2.6L
NFS32 - Need for speed 32...
NYA32 - Only if you like cats ^^
Thats all i got, i go bed now...refers to time posted.... ><
I got
good effort, it must be the late night that did it :P
I've ordered my plate, didn't end up getting any I had on my shortlist which were
32FTW or UNQ32
although I did like ZLR32 I decided in the end I really wanted GTR in it, couldn't get the numbers after I wanted so settled for this one.
    • @dbm7 and @GTSBoy thank you both very much! will give that a shot!
    • Sounds good. Provided the panel is flat/level I'd be happy to start the painting process.  While you are learning, for sure you could do this. Its only paint, you can always sand it all back and start again. Its only your time and money on materials, but while you're learning, really its time and money spent on your education.  Once you know how to do this bodywork and painting, you won't want to waste your time and money on frivolous activities lol.
    • Yep I will use a guide coat after putting filler, I will do it on the whole panel as I'm a beginner so chances I've made quite a few errors. In that photo, I think that was a low spot, I just for example said to pretend it's flat but I will put filler + guide coat after to assess where I'm at. Yep with that picture, the panel is wet as it rained when I took the photo. But all those scratches are completely smooth, I went over it with 240 grit and can't feel it, even with my nail digging into it. I was legit thinking to buy a 2k can and spray primer to see how it turns out but then thought to myself it's going to be a mess doing it haha. Good mention there. Thanks for all that info I think I know what to do next.
    • Prior to laying down the primer, you need to make sure the surface is completely level. For example, based on this picture, I strongly suspect that the areas marked in blue are higher then the area marked in green.  If you spray primer over this entire area, then paint and clear it, the finished result will 100% show the low area. It will stick out like dogs balls. Unfortunately the paint won't magically level out the low areas as you lay it down.  Without seeing it in person, I expect that the green area will need to be filled, then use a guide coat and check that the entire repair area is level with a large sanding block.  With this picture, are you saying that even though you can see the scratches, the panel is in fact completely smooth and flat? If this is the case sure you could prep and paint it as it is.     The picture with the paint you described as blistering, it's hard for me to comment on from the photo alone. It looks like the panel is wet? Dunno, looks strange. Does the panel feel as smooth as glass when you run your hand over it? **** Going back to your question again, generally you would only sand the primer if you made a mistake while laying down the primer.  If the panel is prepped properly and you lay the primer down properly, you should not need to sand the primer.  This wouldn't work - Don't prep the panel. Spray primer and see how it turns out. Sand the areas where the issues appear. Spray more primer and see how it turns out. Sand the areas....... Yeah you'd go round and round in circles getting no where.
