C'mon you're all a pretty creative bunch
Give me some ideas for my GTR using the top two combinations (sorry, I'm not into paying thousands for plates) to keep it around the $500 mark.
http://www.ppq.com.au/CreateAPlate.aspx
https://www.sau.com.au/forums/topic/223423-httpwwwppqcomaucreateaplateaspx/
I have seen "TI3VOM" and "PMS 247"
How about - 60J1RA "Go ji ra"
The only one which falls into the $400-500 category is PMS247 and I don't think Mark would drive it with those on :banana: btw, its taken
I came up with MYTR. Its not cheap, but: Mightier, MY GTR. Its available, but yeh they reckon about $2300.
GTR320 is available and cheaper too.
Thats all I have.
Edited by datto260Z
I got
280BHP - if you feel like keeping your gtr stock...unless that is too late then forget that...
26LTT - 2.6L twin turbo
ZLA26 - Godzila 2.6L
NFS32 - Need for speed 32...
NYA32 - Only if you like cats ^^
Thats all i got, i go bed now...refers to time posted.... ><
I got
good effort, it must be the late night that did it :P
I've ordered my plate, didn't end up getting any I had on my shortlist which were
32FTW or UNQ32
although I did like ZLR32 I decided in the end I really wanted GTR in it, couldn't get the numbers after I wanted so settled for this one.
    • Read the ECU for fault codes or have someone else do it. A faulty coolant temperature sender is usually listed in ECUs. If the sensor itself is not busted it can also be a bad ground connection. Or in a really unlucky case, damaged wiring.
    • Can't be a Futjitsubo as those are made with a flex piece and Reimax is smaller in pipe diameter. If anything it is closest to a Mines pipe, but evidently it is not an actual Mines pipe.   Classic word humor
    • Alright I will try to not forget.   As GTSboy replied to you already, problem is mainly the mismatch between the actual exhaust part and the denomination in the papers. That basically just looks like tampering to a cop, if they were to check your car and notice. If it had been done right they would have clarified it to be a custom pipe and just given it a certain part number that you have to engrave or weld onto the pipe. I will definitely inquire on what to do. Changing the pipe wouldn't be my favorite solution as it costs a bunch of money and the cat was fitted with the front pipe and exhaust under the car, and if the front pipe flange does not sit in the OEM location the cat will need to be refit for any other pipe to work. It also usually doesn't need a brand name or something like that, but more something like a part number. Usually for exhaust parts, on silencers and cat units specifically, there is a badge that reads the certificate number that belongs to these exhaust parts under EU regulation. You get these numbers after you put a part or group of parts through the tedious testing according to EU vehicle legislation and they pass. You can find these "part numbers" on various parts throughout a EU vehicle. On windows, headlights, engine parts, seat belts and so on. All these parts have gone through standardized testing and acquired a so called ECE or EG Certificate that makes them legal to use by themselves in all countries that adhere to these standards. You can also not alter these parts in any way, if you do they become illegal. An example for stampings on an exterior lighting part, the people who need to know can find the documentation for this unit in a database. I do not know what all the standards and so on mean.
    • If that was the case I suppose you could call it "Mein's" brand....  ... I'll see myself out... 馃槄
