just wondering where the best place is to get a r34gtt power fc. is it best to get one with a hand controller or is it not neccesary. do all power fc's allow removal of the airflow metre or does a specific one have to be purchased. im not to sure about putting $1500 or so through ebay so im looking for else where.
https://www.sau.com.au/forums/topic/223454-power-fc/
Hey dmonic1, might be worth doing a search for Power-FC info as there is heaps and heaps of threads relating to them. Primarily thou the standard type PFCs use the cars stock AFM, its only a couple of the higher end units like the d-jetro ones that don't. With this sort of thing people are selling them off all the time as you can get pretty good money for them resale, as aposed to other car parts. You can usually pick one up for a few hundred bucks cheaper than new one. The Hand controller is used for tuning the car and in my experience if you using it as a daily driver type car you won't be changing the settings over, the PFC doesn't have multimaps or anything like that so u can't simple switch between Race and Street settings you need to manually change lots of things to get a different result. So really the hand controller is just used as a guage for a few different things like water temp and such. With regards to getting it tuned if you are going to a reputable performance type place they will more than likely hook their laptop upto the FC anyway so the hand controller is probably not needed in that regard.
https://www.sau.com.au/forums/topic/223454-power-fc/#findComment-3936715
Have you got an auto? If so have a read through the threads for raesons why you won't want a power fc
If you still want one here is one for NZ$2300 (Soichi is a top Japanese tuner working in Auckland) there are other, cheaper ones on Trade Me.
http://www.trademe.co.nz/Trade-Me-Motors/C...n-159578655.htm
https://www.sau.com.au/forums/topic/223454-power-fc/#findComment-3938040
My 20 cents;
1. You can use pretty much any decent Nissan AFM with any Power FC, just select the appropriate one from the menu. I have seen over 1100 bhp through AFM's so using them is hardly a power constraint.
2. I use the Commander for all sorts of things, a few examples. I can turn the boost down, or up, if I want, in a few seconds. This is useful for track days, inexperienced drivers, a night at the drags etc. I can retard the ignition timing any number of degrees, this is usefull if I get stuck having to use sub standard petrol in an emergency. I can increase the idle speed on a hot day in traffic to make the air con cooler. Or to circulate the water faster if the temp is creeeping up. All of the engine sensor outputs are shown live on the Commander, using it as a diagnostic tool it is a simple process to find one that may be faulty. I can check injector duration, engine knock levels, AFM voltage etc etc. For tuning a lap top is definitely the go, but once you learn to use it, a Commander is a very useful tool in its own right.
Cheers
Gary
https://www.sau.com.au/forums/topic/223454-power-fc/#findComment-3938230
I don't disagree that the hand controller is totally worth having even if you don't plan to muck around with it but im saying its not totally necessary.
I am in the process of trying to buy one and everytime one comes up it slips through my fingers...
https://www.sau.com.au/forums/topic/223454-power-fc/#findComment-3938932
Luckily for me i have an RWD so it will be a plug and play with out wirring issues as i actually have traction control. yes i have an auto but it will very soon be shift kitted and if that fails i wont have any problem putting a manual trans in there due to only having a RWD in the first place. the ebay price is about $1500 new with a hand controller. does that sound about right.
https://www.sau.com.au/forums/topic/223454-power-fc/#findComment-3939050
$1500 is reasonably pricy if i was you id acutally contact a quality installer in your area and ask them what the price is of supply, install and tune. You may find that its not more expensive as they will make there money on the install not the equipment.
just my 2cents
https://www.sau.com.au/forums/topic/223454-power-fc/#findComment-3940201
How much do you want to pay? Here's one for NZ$300 (plus postage I guess)
http://www.trademe.co.nz/Trade-Me-Motors/C...n-159348844.htm
https://www.sau.com.au/forums/topic/223454-power-fc/#findComment-3940650
r34 gtt PFC is out of production so 1500 is about right for market price. you should check my other thread for issues around vin#s, build dates and ECU versions - if yours is S2 I think you might have challenges. Only the early model s1 fit straight into r34 gtt PowerFC
https://www.sau.com.au/forums/topic/223454-power-fc/#findComment-3942050
hi duncan
actually dmonics car might be the only real bolt in powerfc for a stagea.
his is rear wheel drive with TC.
so almost certainly it will bolt in and run it like on other S2's BUT the engine check light fault from TC won't be an issue (like on the 4wd stageas).
Edited by wolverine
https://www.sau.com.au/forums/topic/223454-power-fc/#findComment-3942135
i finally fitted some splitfires and boy what a difference it makes to not have a car spitting everywhere. i just picked up a second hand pfc with a hand controller for $850 on ebay. now just have to sit and wait. my turbo will be ready on tuesday from ATS. Bill is building me a highflowed dash 12 gt3076 for $2300 and my front mount from cooling pro should arrive by the end of the week. then all i need is a weekend to fit it all and get it tuned. my main aim is to have it looking stealth under the bonnet so i reckon all i will do from here is a set of cams to lower the compression a little bit and that will be it. i will probably just run 10 to 12 psi for a while until i can afford some injectors. any idea what sort of power i can achieve with the stock injectors. i would like to get eventually in the area of atleast 250 but would like about 280rwkw. should make for a fun RWD stagea. will post up some pics of the turbo when i pick it up.
https://www.sau.com.au/forums/topic/223454-power-fc/#findComment-3942928
