  • Replies 461
Posted Images
next race im bringing some super glue to make sure the spark plug leads dont come off :thumbsup:
Ok if we are allowed to bring our own parts etc....i think i might bring some AVGAS! Will have to limit the endurance race to say 4 minutes though!
LOL
Thats sounds like an allegation!
You wouldnt be alledging things with no proof surely?
No, I'm sledging with proof :thumbsup:
4 mins?!? isn't that 4x times longer than you normally last??
I must have been pushing to its limits and then blinked at the wrong time. I'm good knowing it was my very first outing.
Not good enough to walk away with the grand daddy of prizes!!!!
Might let you hold the trophy one day..... Will need to clear it with my Co Driver
Sorry mate but i would have to decline that request.
The trophy is not a toy! Its a symbol of eliteness in driving....its just not for everyone!
Yeah we were chasing the back of the field to put laps on everyone......
Come on Lyell you should of known that seeing as we put a few laps on you......
Your comeback attempt is a FAIL!
You only put laps on us because YOU SABOTAJED OUR KART!
Your sledging attempt is an epic FAIL.
Edited by bubba
C'mon Mike, hounds chase things, you must be settling into the idea of losing your crown soon :D
We have already engrqaved our names on the first 3 spots of the trophy as we will win anyway. (only do 3 as after that i may retire) :(
LOL you will need to wear your helmet constantly if you keep it up , swelling will never go down :D
LOL you will need to wear your helmet constantly if you keep it up , swelling will never go down :blink:
What you going to do Bart? Ram me again? LOL
Must admit when you rammed me i knew it was you, the only thought i had was "how rude!" lol
    • Way more than 1cm. Appreciate the advice maybe I try changing the bushing first
    • IMG_8641.mov     She doesn’t sound the best but starts with out using any gas now. I just ran some injector cleaner through her. started roughly the first time after adding it but gave it the beans slowly upto 4k, Must have cleaned a few cobwebs out. another step in the right direction for the sub
    • Sadly I can confirm if you are actually seeking to drift, you will quite easily spin up one wheel. Even if you're going in a straight line. I am not entirely sure of the metrics/terminology here but there's only a certain amount that the helical will actually spin both wheels. I've seen it on video with my own car where two lines of smoke switch over to just one after you really get in to it. Unlike with a clutch diff where you can keep your foot planted until the car regains grip, in my experience with the helical you want to be utilizing traction control allowing LIMITED slip or lifting (partially) when you start to spin up both tyres with a Nissan helical. Which makes them pretty sub optimal for drifting duty. That said... this is probably a helical on numbers alone. Just put the Kazz in
    • Let's just fix the problem by f**king the rest of the gearbox.
    • Unlikely, as per Greg's post. This is not helical diff behaviour unless one wheel is up off the ground. Shimming what? You don't "shim" a mechanical LSD. Probably not in the sense that you have heard of people "shimming" a diff. And the process that Nissan f**kwits call "shimming" a diff involves super-preloading a VLSD cartridge against the side of the diff to create a friction/wear point (in a place that it wasn't supposed to have one) to make the sloppy, useless, viscous diff into a hybrid viscous/mech abortion. In case it isn't clear, I consider the process to be stupid. Nike.
