I've searched and this seems a popular topic but there is very little info on where to actually source parts.
Ok bearings are easy to find and you can get the synchros genuine.
I rang Nissan and a set of synchros would cost $613.
They said there appeared to be 2 rings needed for 5th gear so six rings in total.
Interestingly the part numbers are the same as '95 V6 navara 2wd synchros.
I rang a bearing supply place and they quoted me about $200 for the basic bearings seals and gaskets or just over $400 for a full bearing/seal kit with all the needle rollers etc.
They said they might be able to supply synchros but wanted my vin no. which I couldn't give them as my car is an r32.
I bought my r33 box 2nd hand and don't know what year model it came from but it has a push clutch.
Are there differences in g/box parts between different years ecr33?
Could someone please post legit vin no. for each year '93 - '97 manual ecr33 so I can compare the synchro part nos.
I'm waiting on a email reply from a company in the us advertising rebuild kits for the FS5R30A gearbox which is the same number box as the r33 turbo, 300zx, 2wd navara and gtr box in 4wd form.
Has anyone here found the synchros etc cheaper than buying from nissan?
https://www.sau.com.au/forums/topic/223475-r33-turbo-gbox-rebuild/
im getting mine done at the moment at the gearbox factory in revesby. ive been quoted 350 - remove and refit, and 850 for a full reco
The parts I've priced for a basic freshen up assuming no parts are broken is over $1000 so $850 including labour for a full rebuild sounds too good to be true.
What is wrong with your box that it needs rebuilding?
It might be a good idea to make sure you know what parts are to be replaced and ask for all the old parts back.
    • I'm pretty much healed up post surgery so I spent another almost full day out in the shed re-arranging everything to make room for all of the shit that I've taken off the car.  I need to get everything off the floor and away from the car for when I start making a massive mess stripping off the remaining body deadener and then for the the painting process.  Almost got the shed to a point now where I feel I can actually start working on the car again (clean shed clean mind or something!).  Almost 11 years of accumulated car parts, building supplies, tools, junk, etc have taken a long time to get in some sort of order again!  Most stuff is now boxed up and in the back shed if it's not car related.  Most people would still be horrified walking into my shed but it's significantly better than it was before!   For those that saw my separate post the other day, yeah I ordered one.... This version- I convinced myself to stop being a clown, wake up to yourself and realise it will take you 5 weeks to make one by which stage you're over working on the car again...  Maybe I am getting on top of my "mental ailments" and making smarter choices.... $1450 delivered which will take my miserable half-dutch arse a few days to get over having spent that much!  If I don't have a use for it straight away after my car is off it I might even see if there is a "rental market" for them.  See if anyone wants to hire it for a period of time.  $25 a week or something like that.  I'll worry about that when my car is actually ready to come off it though as that might be a while away!! There's now no excuses now for not ending up with an underside you could eat off! Away for kids sport the next few weekends so hopefully can get the rotisserie assembled ready to go for the car to go straight on it the next available weekend.
    • I always use my Karcher, but it's only a little one that I picked up from Supercheap  The only issue I ever had with a pressure washer was when I was a kid cleaning coaches, they had a hi-po industrial sized petrol jobbie that would strip paint if you got to close I saying this, we have a fairly high power washer at work with a diesel powered heater that sprays water at about 60°c, it works great for removing old wax and road grime on the underbody after some foam cannon action, albeit from a "stand off" distance of a few feet
    • Sorry no - The sandtrap adventure ended the day, happened at the end of the last session. At that time I wasn't hearing any weird noises nor were the brakes shuddering anymore. It was only when watching the videos that I remembered I had these sounds early on!
    • Did the noise appear after your sand trap adventure? Could be something got dislodged and is playing rub rub. Even a rock wedged somewhere.
    • Is there a shroud around the tailshaft spline into the back of the box? They can rub and make a horrible noise if they are not on straight/damaged. The heat might have caused it to grow too much in one direction and rub.
