ok more to the point will it fit if i convert to a push setup and has anyone done one i have a list of part numbers from nissan but unsure on cost and if its worth it. I have noticed gtst clutchs alot cheaper like $160 for stage 3 single button ceramic that one for a gtr around $400, so the extra $$$ is because they are pull rite?
Part Numbers :
32110-05U11 Front Cover Assembly
32112-05U11 Front cover gasket
30531-01S00 Clutch Fork
30534-E9000 Pivot Spring
30514-14600 Sleeve Spring
30502-14601 Clutch bearing
30501-B6064 Clutch bearing sleeve (20mm) OR
30501-N8474 Clutch Bearing Sleeve (30mm)
30542-31G10 Clutch fork dust cover
30620-21U01 Release (slave) cylinder
30855-05U00 Slave cylinder hose
The GT-R clutches are probably more expensive simply because they are for a GT-R.
How much are you likely to spend on the conversion simply to save some $$$ on the clutch plate? The push / pull difference is in the pressure plate, not the driven (clutch) plate. The pressure plate doesn't appear in your parts list.
yes well after the the conversion a new push clutch will be installed so new pressure plate also the os gekin clutches use push and come with a conversion kit i found after abit of long hours looking up random sh*t, also the os giken conversion kit is $500
