Hey,
Anyone had experience with operation of Mongoose M80 central locking option? I took my car to the mechanics yesterday and i believe that they have pressed the keyring fob buttons in some sequence to disable the central locking function.
The immobiliser still works the same, and the central locking works (if i use the key on the drivers door it drives the passenger door) but the remote central locking function does not.
does anyone know the code?
Jase
It looks like the central locking is working (if i use the key on the drivers side, the passenger side opens up) but the alarm is not sending a signal to the central locking unit.
anyone have any idea how these things are set up and what i shuold look for?
J
J
the M80 has on board central locking relay, there will be an actuator in the drivers door that is controled by the m80.
firstly i'd take the drivers door trim off and you should see either a set of blue and green wires of 5 wire system connecting to the actuator that pushes your locking arm forward and back make sure they are connected properly sometimes the window can pick up cable and disconnect. if all good then id disconnect the blue and green and use a test light and individualy test each wire for pulse while pushing the arm and disarm buttons. if no light when you do then then i'll tell you what next to do.
very rare for mongoose m60 or m80 to fault so id say it's the actuator but you can check the 2 10amp fuses on the m80 module aswell. there are 6 fuses in total wont hurt to check all but the central locking fuses are seperate to the main loom.
most the cars that come in with central locking problems have actuator problems, so let me know how you go or call me if you r having problems
WFS Car Audio and Security
Nathan 0413017118
Edited by 17SQK
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
