Hey guys,
In need of a new diff center.
My r33 gtst has a 4:1 diff in it, will i need to get another of the same ratio or can i use a 4:3?
If i use a 4:3 will it make much to any difference? and will i have to change anything in regards to speedo reading correctly?
Thanks
https://www.sau.com.au/forums/topic/223501-41-vs-43-stock-lsd-in-r33-gts-t/
No reason why you can't use a 4.3 . You will gain a slight improvement in acceleration. The speedo will read slightly high (you won't be travelling as fast as the speedo says). The engine will run slightly higher revs at a given gear / speed.
