Anyone out there will to let me borrow there pit or hoist for as little as half hour... even for a small fee. need to change my oil. i live on western side but will drive anywhere for access...
a workshop offering a pit to lend out for an hour would make a fortune...
https://www.sau.com.au/forums/topic/223550-pit-or-hoist-to-lend/
ay rick i will ask a close mate of mine his in airport west off matthews ave..
if he isnt to busy i might change my oil aswell same time, but this will be a after 4.30pm thing..
will post in here 2moro and tell ya the times available, if available...
havent got a trolly jack, drive way or anywhere to do it really. and just moved to this so pit or hoist will come in handy. clus i can have a good look at the bushes as thers a bit of a clunk coming out of the car. just moved to melbourne area from SA and dont have money to pay for someone else to do it when ive always done work on my car my self.
chris r31 PM Sent
when past 2day rick and as expected he is full.. he dont open sundays as he doesnt need to..
but if your still stuck by next week, he will call me and try arrange for something..
kaz he is on king street, lol and thats all im saying...
i could do it my self no worries if i had a decent jack that would fit under the car. we got rid of everything when we made the move over here... even my massive tool set.
as for people not lending there hoist.. that was expected.. i was just curious to see if anyone has thought of opening there doors to people on the weekends as im sure im not the only person. cheers though
Comes down to insurance, your not an employee so they are in the sh|t if you do something wrong (just something to think about)
Maybe you could invest in another trolley jack?
Would pay for itself after the first 2 uses id imagine saving workshop labour fees :)
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
