Hey,
Background Information: 350-400hp R33 GTS-T driven rarely on the street, mainly used for track work
Im currently running stock r33 gts-t radiator and radiator hoses. Im looking to upgrade, im not interested in anything china so please dont suggest it. I'm not sure what size i should go and if i go for a larger size i will have issue with head soaking.
Atm im looking at Nismo, ARC, Trust or Koyo. Nismo and ARC and both similar price and at the higher end of the scale.
Any input on size and brand would be great. Also would it be in my best interested to replace the stock clutch fan with twin thermo fans setup? And if so how do you go about removing the stock clutch fan?
Thanks Michael
Edited by [Michael]
https://www.sau.com.au/forums/topic/223592-radiator-options/
Hey Michael,
I've heard good things about the EL/AU twin thermo fans. There good, flow very well, cheap and have a shroud. Only need to made minimal mods to make it fit (cut shroud and wiring). If you choose twin thermo's make sure you use a shroud to guide the air thru the thermo's.
I'll be running the twin AU falcon thermo's with a Greddy alloy 50mm radiator and a sard breather kit.
The stock clutch fan has 4 x 10mm bolts behind the vicous centre. unscrew them, take the fan and vicous out, then screw the bolts back in as it holds the water pump pulley on.
Hope that helps,
Johno
Edit, there was a company in the states who can do a 50mm Koyo rad for about $450 delivered.
Race Radiators (here in melb)
$660 inc GST replacement for the R33 GTS-t
Brilliant piece of work, ive got one in my car, and a few other guys i know are running them.
Top fabrication on them... in this instance, go the local product :)
Keep the clutch fan also, GTR's here in Melb dont alter the setup and make a fair whack more power than you are.
dont do what i did and weld tanks to a cut down mack truck radiator like i did the intercooler. the only time it gets up to temp is doing circle work at the local burnout pad, the minute it gets a wiff of air flow it cools better than my dads double door Maytag fridge/freezer. lol
ended up removing the coolant temp circut from the ecu completley as it would constantly run rich
Edited by nizmonut
    • Strength. And on the early RB26, full engagement of the pump drive.
    • I really don't understand the point of aftermarket oil pumps if your particular engine doesn't need more oil pressure. As far as I can make sense of it the problem seems to be cavitation from sucking air, maybe the pump gear design with how it interfaces with the OEM crank, and maybe the backing plate screws wanting to loosen themselves. How does flowing more oil fix these issues?
    • More photos are up, and the price has been dropped to $16,000. It's just had a service and a new 12V battery, too.
    • I agree on doing some better than factory pistons, rods, and oil pump. For anyone using the vehicle on the road, I don't get why everyone wants big cams. The stock cam profile, with some more lift would be mint for road usage. Everyone going big cams and then wondering why it isn't as responsive in traffic, when they've shifted the torque curve upwards an additional 1000RPM. Make torque, at lower RPM. Sure it's not as cool as claiming "500KW" and revving it to 8,0000RPM, but that same torque 2,000RPM earlier... Then you don't need the extremely high end pistons and rods, and blah blah blah.
    • Personal experience. Those f**kers burn. And are actually a PITA to put out. Next time I walk down the back, I'll snap a photo of what the inside of the bonnet looks like when that thing ignites. PS, powder fire extinguishers are useless on that stuff too as it's fibrous and when it ignites, it starts to pull apart. And you end up just blowing powder through a sieve effectively.   Like the big thing is, if it's fire resistant, it's job is to stop what burning? The METAL above it? It's just to try keep heat off the bonnet paint work.
