Stagea Oil (type And Viscosity)?
sturb25
 Share
Hay guys, just had a query about what sort of oil u guys are running in your series 2 stagea or r34. Just need help on what viscosity u should be using in a turbo engine. Ive always used mobil one in the silver bottle 5w-50 on my vl rb25det, is this ok for my stagea. If theres any suggestions on what oil would be ok ur help would be appreciated
i made a post about this in the ACT forum i think, basically for an australian climate a 40 weight oil is what you want for around town use, either a 0w40 or 5w40 would be fine. certainly not those 10w60 oils, they are too thick for around town, the oil doesnt get hot enough unless your racing the engine. 5w50 is in the middle so it would be ok for a hot climate, but melbournes not that hot right....
i use 15/50
After extensive "research" I concluded that synthetic was the way to go and Amsoil was top of the pops but when I finally tracked some down it was going to cost $200 an oil change so i flagged that and am using Castrol Edge 5W- 30. No problems so far and am planning to change the filter every 10000 and keep the oil for 50,000 but i will keep an eye on it.
  • 1 year later...
Old thread i know... but i've been using Motul 8100 x-cess 5/40, was thinking of getting the Mobil 1 5/30 for next oil change. About the same price. Would that be alright? Anyone using it? Or is 30 too thin for a 110,000km engine?
Nissan recommends a 7.5w/30 oil.
I have been using this one lately, ProSYN 730, http://www.synforce.com.au/synthetics.html, which is right on the specs, not that it really matters, but noticed my engine lifters are quieter using this one compared to the OW or 5W oils.
I found Fuchs 10w30 was the best for economey and kept the motor quiet and sounding smooth
I would try it out, i prefer a 10w30 in my 120k km motor, i used motul 10w40 this last service and the motor sounds harsh and the top end/head is louder.
i enquired about this fuchs stuff you talk or ryan... i am currently running castroll edge sport 5 30. Have been told putting fuchs in would be going backwards big time.
castrol edge sport 5/30 sounds good.
Ive kept to 5/30's and 10/40's, from Fuch, castrol edge, mobil 1, Pentrite's etc, currently using Martini Racing Oil and seems really good.
...... 10/60
"Martini Racing Oils - Sint 60 R/T
Competition, High Performance and heavy duty 10w60 SM motor oil suitable for most Turbo and non Turbo Road & Track engines.
Sint 60R/T is a high quality full synthetic 10w/60 racing lubricant specifically formulated to satisfy the demand for an outstanding product that will ensure maximum engine protection and performance. Sint 60R/T is suitable for the “race” engine that operates at the extreme end of competition for prolonged periods of time. Sint 60R/T is also suitable for high output, high performance road cars that require maximum performance and protection from a synthetic engine lubricant API SL-CF
Sint R/T Engine Oils meet or exceed the following specifications:
API SL, SM IIsac GF-3, ACEA A3-96, B3-96, Ford ESE-M2C - 153E "
..... also 5/50
"Martini Racing Oils - Sint 50 R/T
Competition, High Performance and heavy duty 5w50 SM motor oil suitable for most Turbo and non Turbo Road and Track engines
Sint 50R/T is a high quality 5w/50 full synthetic lubricant suited to the extended oil drain intervals offered by BMW and other leading engine manufacturers. It greatly reduces engine wear and friction while increasing fuel economy. Sint 50R/T meets the latest requirements for modern high technology performance engines and is formulated to be low viscosity at cold temperatures therefore providing greater protection during start up. It reaches maximum viscosity at high temperatures ensuring greater resistance to breakdown in harsh operating conditions. Superior Synthetic formulation guarantees maximum protection for high tech-high output, turbo and non turbo, petrol, L P gas and diesel engines. API SL-CG Islac GF-3
API SL, SM IIsac GF-3, ACEA A3-96, B3-96, Ford ESE-M2C - 153E"
M4_Martini_Sint.pdf
mmm the only mechanics i have had tell me to use castrol had castrol everywhere, where the ones that agreed with my fuchs choice over castrol used neither...
Well the owner of my local RB workshop uses a top line Motul (which makes Mobil1 look cheap) in his 10sec R32 and suggested my change from Castrol Edge 5W30 to 10W 60. I do a few track days and give it heaps on the road so it usually gets up to full operating temps.
I think any quality synthetic would be fine ... I would spend more time on tyre choices.
:D
Amsoil is "only" a Grade IV oil. It is good (I have used the 10w40), but it is only the best if you listen to their MLM hype.
If you want to get some, try HERE
I know they are in Melbourne, but I am sure they would ship it to you.
Dunno about the 10w60. I use the Motul 300v as well, but the 10w40 Chrono.
The car feels sooooo much better with it than with any of the other oils I have used.
HIGHLY recommended.... costly though :thumbsup:
I've been using the Nissan branded 'Special Blend'
which they recommend on their turbo vehicles.
From memory its 5/40 or 7.5/40.
Change it every 5000km, still quite clean and viscous at these intervals.
 Share
    • Gosh these bmw's are worse money pits than JDM's! I won't complain about my car anymore 😂
    • I'll just leave this quick tip here after reading your joys of getting the car in the air. It should take no more then 10 minutes to get the car safely up on stands.  So for the front, jack on the tow recovery points (marked in red). Put the jack stands under the lower control arm mounting point (marked in yellow). This photo is of a R34 GTR, however the process is the same. For the rear, jack under the diff (marked in red). Put the jack stands under the rear subframe or where the lower control arm mounting point (marked in yellow). Which point you use will depend on your stand, pick a nice stable point.  You've probably already read this but it's worth repeating. When jacking up the car or using stands, stay away from the chassis rails/pinch welds. Even the factory jack point, stay away from that too unless using a factory jack. I used those jack points for years without issue until I turned into an old man and bought a QuickJack lol.
    • And this is where the leak is happening: https://www.dropbox.com/scl/fi/7h1vlmg2j5aa7rksvsjc9/IMG_9982.jpeg?rlkey=d3bnpau5f615zmxqmca0llvr7&st=kquvdxvs&dl=0   Apologies but it seems adding an image from a link does not work when the images are in Dropbox.
    • Here are some pics from the auction: https://www.dropbox.com/scl/fi/gkbfaa7urogzhyzxtdgq4/4cd77e2d-e19f-45fb-80a0-f9a88fd7f51f.jpeg?rlkey=39p7xyvgr33kj0avcjry2v4ap&st=ncxmagj4&dl=0   https://www.dropbox.com/scl/fi/gkbfaa7urogzhyzxtdgq4/4cd77e2d-e19f-45fb-80a0-f9a88fd7f51f.jpeg?rlkey=39p7xyvgr33kj0avcjry2v4ap&st=ncxmagj4&dl=0
    • Hi all, From the western suburbs here. Just got my 2000 R34 GTT registered today! Got it imported from Japan through a mate who is doing them and managed to find a decent one. This one has only done 110,000 Km and had no body rust etc. so was very happy. I used to own a 25Gt back in 2015 (ate Ramen noodles for years to save up for it), but unfortunately, it got stolen TEN DAYS after I bought it!! Came back from Uni and the car was missing - cops found it in Springvale a month later with a lot of needles  😒 It was too late by then and I had moved on to a different car (300ZX), and after that one got broken into around 2018, I was in a very bad place and decided I would never buy a car again because it was just pointless!!! ~yeah, I have some very bad mojo~ 🥺 But now, with a stable job and a secure garage, I thought I'd get the R34 4D again but not as a daily! I love the R34s but a GTR is still a bit off my pay grade so settled for the GTT instead.    The first step for me is to get this car serviced and have all fluids, belts and spark plugs changed. I might do the brakes at one point too but atm they are fine, the fluids are what I want changed since this car probably sat in a garage for a long time. I'll then get some coilovers since the suspension needs to be changed anyway (the dust cover kit is disintegrating). I'll also upgrade my car alarm to a Viper system and then look at rims and tyres (I'm a sucker for TE37s - might have enough saved in another 3 years for that).   Today: I was planning to do the oil, coolant, air filter and fuel filter change this week. Started on the oil change today and MY GOD what a pain!! I used to think the 300ZX engine bay was cramped - oh I was so wrong! 😂 I've done the usual services on my cars before so it was not like I was going in blind. I looked up all the forum details about what oils to use, what coolant to use, what points to use to jack the car or place stands etc but I did not expect it to be this hard. Long story short - all I managed to do was the oil and filter change. I think I might end up taking it to a mechanic for a coolant change because my SCA stands and trolley jack just can't get far enough underneath to the cross-member and I don't want to be crushed under my favourite car....yet. Side note: In Dandenong, there used to be a shop that lets you hire their hoists - does anyone know if they have those around? I can't seem to find the Dandenong place anymore. I contacted them off FB almost 6 years ago and I'm not in it now. If anyone know of one, that would save me some time going to a mechanic for the basic services. Oil: Dark and gooey but no metal pieces. Oil Filter: Was a b***h to take off but no red flags Air filter: Yucky! Was black (Smells like fuel which makes me think it may have been running rich? - am I way off?)   Concerns: I have but one concern atm and that is that there was a very small amount of oil leaking where the engine and the transmission connect (Automatic). It may be the rear seal? It's not a massive leak and it does not affect the oil pressures or leak oil all along the driveway. It's been falling into the cover this whole time. I've taken the cover off so I can check the garage floor from time to time.  I also have not seen my engine temperature gauge ever sit at cold and slowly move up to the right spot, but that might be because every time I saw the car today, it was running. I'll check that again tomorrow. ATM it just sits right in the middle. I may just be paranoid but I don't want an overheating engine while my gauges say everything is fine. 🙈 Other than that, I'm very happy with the car! Feels like it's about time I went back to spending my weekends driving or cutting my arm on stupid sh*t in the engine bay.   PS: I will post a pic later on because I underestimated soooo badly today and it was dark by the time I finished! PPS: I broke the two damn plastic pins that hold the intake funnel section to the front bar. This is the piece made to bring cold air to the airbox. The connection to the airbox is fone, but the two clips just broke off! Should I be worried? Anyone else done that?
