Hello everybody!
Unfortunately I don't own one of your macho cars/engines but I do respect them. :wub:
What I do own is two R33 clusters. One of them is coming from an automatic with the connectors and a piece of the harness on.
I would like to use them on a 4-cylinder SR16VE.N1 engine. Is it true I need some kind of device to manipulate the rpm signal?
I had no luck in finding any dash wiring diagrams besides some regarding the R34 MFD.
I suppose the only difference between a manual and automatic cluster are the extra wires for the gears indicators.
Is that oil pressure dial accurate? I've heard that the stock oil sender often fails. Could I bought a sender and use it or could I use and aftermarket sender? Could a sender be used in parallel to drive two gauges?
Thank you in advance.
Edited by Out Of Sight
sorry to pop your little balloon there buddy but i hope you had the foresight to get all the sensors aswell? if not those are pretty much paperwieghts as none of them will be acurate as the sr16ve sr20de rb sensors all give out differing readings.
the nizmo cluster you'd be better off selling to whom it would be useful, i.e. a r33 owner.
Edited by nizmonut
Don't worry I make balloons everyday so they don't pop out that easily... :wub:
Europe drivers besides Northern countries and UK are not used to drive right hand vehicles. They also face silly law restrictions for importing and registration. So whenever we see one these beauties over here everybody takes a camera in hand and starts chasing it... :(
RB engine conversions have just started to become popular. S13 CA18 guys used to upgrade to SR20DET.
So that cluster belongs to me... I could turn it around be hand and imagine I drive that high...
On which sensors are you referring to?
Speed meter sleeve is incompatible with SR transmissions.
Cluster water temp sensor 25080-89907 is the same.
Oil pressure sender 25070-30P01 can be also found on S15/Z32
All the others are simple switches.
Purpleline has provided me an awsome cluster wiring diagram in case anybody else needs it.
I'm kindly dissapointed cause cluster needs modification to fit my vehicle but besides that stock ecu does not drive the tachs at all. Just a small wag on startup.
This device might help people doing similar conversions.
  • 3 months later...
    • yeah i agree paint match stops it from standing out so much, oh that's actually really good to know i was wondering if it would help with air flow now actually having an outlet in the bonnet. Will have to focus on ducting into and out of the radiator now to make the most of it.
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
