Hey guys
Quick question, what is this part on an R34?
I know R34's have antenna's in there back windows built in an stuff.
But when i got my car i got this antenna looking thig at the back aswell.
Dont get me wrong it looks good an all, just curious as to what its used for?
A friend of mine said it may be a booster for the factory antenna?
Heres the pic, its the red bit i circled
https://www.sau.com.au/forums/topic/223671-r34-antenna/
Was it there when you bought the car from Japan?
The rear windscreen may have been changed and replaced with the antenna you got at the moment.
Or you car may have had a TV / GPS and used to pick up better reception.
https://www.sau.com.au/forums/topic/223671-r34-antenna/#findComment-3941405
Yeh it was there when i got it from japan
I checked the rear window, it has lines running left to right which is the antenna, however at the front window of my car theres 3 lines running down the left, right and top of the windscreen, was told it was the antenna for the suppose TV that was in the car, though i didn't get the TV when i bought it.
Its strange as i haven't seen any other 34's with it.
But thanks for your replies guys, i guess its safe to assume its for the TV.
If we ever have a SAU meet up i'll show you in person ahahaha....
Thanks.
https://www.sau.com.au/forums/topic/223671-r34-antenna/#findComment-3941547
Thanks.
Well if the previous owner had a TV installed, they would have took it with them. Its an aftermarket item.
To show the GPS / DVD Satalite Navigation or watch movies ect + And if it was a GPS DVD Sat / Nav, you would have to get it converted coming to AUS anyway.
SAU Meet up... Yeah sure if you are wanna drive all the way down to Melbourne. LOL!
https://www.sau.com.au/forums/topic/223671-r34-antenna/#findComment-3941601
sorry to hijack the thread, but i have 4 wire looking areial things ont eh front windhsield, anyone know what these are? they look like rear demistes but are on the froint
Are they stuck onto the front screen?
If so i got them too lol, i was told it was the aerial for the TV that was in my car before it got over here.
https://www.sau.com.au/forums/topic/223671-r34-antenna/#findComment-3949948
    • This has clearly gone off on quite a tangent but the suggestion was "go standalone because you probably aren't going to stop at just exhaust + a mild tune and manual boost controller", not "buy a standalone purely for a boost controller". If the scope does in fact stop creeping at an EBC then sure, buy an EVC7 or Profec or whatever else people like to run and stop there. And I have yet to see any kind of aftermarket boost control that is more complicated than a PID controller with some accounting for edge cases. Control system theory is an incredibly vast field yet somehow we always end up back at some variant of a PID controller, maybe with some work done to linearize things. I have done quite a lot, but I don't care to indulge in those pissing matches, hence posting primary sources. I deal with people quite frequently that scream and shout about how their opinion matters more because they've shipped more x or y, it doesn't change the reality of the data they're trying to disagree with. Arguing that the source material is wrong is an entirely separate point and while my experience obviously doesn't matter here I've rarely seen factory service manuals be incorrect about something. It's not some random poorly documented internal software tool that is constantly being patched to barely work. It's also not that hard to just read the Japanese and double check translations either. Especially in automotive parts most of it is loanwords anyways.
    • If you are keeping the current calipers you need to keep the current disc as the spacing of the caliper determines the disc diameter. Have you trial fitted the GTS brakes fit on a GTSt hub or is this forward planning? There could be differences in caliper mount spacing, backing plate and even hub shape that could cause an issue.
    • Hi there I have a r33 gts with 4 stud small brakes, I'm going to convert to 5 stud but keep the small brakes, what size rotor would I need?
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
