Hay guys, I have an rb25det that was rebuilt 25'000km ago. Have reciepts for work done and dyno sheet with 194.8rwkw on 12 psi with haltech. does not come with ecu but with standard loom. Have the head off at the moment 4 photos of under the head and cylinders showing hone marks. Just wondering what it is worth?
https://www.sau.com.au/forums/topic/223685-rb25det-going-price/
whats it rebuilt with? What was "rebuilt"?
Sorry, silly me forgot to give details. The bottom end and top end were rebuilt using Standard internals (used original pistons, standard bore size), new rings and bearings and mains fitted, crank grind, block decked, head pressure tested and shaved, new guides and valve stem seals, reseat and grind valves. New gasket kit. I may of missed a few things but everything was done. Will check my receipts when i get home and repost anything ive missed. Turbo wasnt touched as it was checked and didnt need rebuilding said the machine shop where all the work was done.
Well I don't think that is considered a "rebuild" as such.
It's more of a "freshen up". Depending on who buys it I don't think you will get more than $3,500.
Thanks i should of said reconditioned then. because rebuilt means with new pistons right?
It is open to interpretation I think :domokun:
But usually most people will refer to a rebuild as all new (usually performance) internals.
I am curious as to why you didn't do a full re-build on this engine as the labour would have cost a bit? Or were you in a tight spot and needed the vehicle back on the road?
It is open to interpretation I think :)
Bit tight on cash and needed to get the car on the road, had it in a vl. I bought the engine from sss, when i bought it it had 40k on it so i just decided to use the original internals and just 4 my peice of mind i had all the work done so it was basicly starting from scratch, fresh. I had it sitting in my shed for 2 years b4 i had enough cash to do it and god knows how long it had been sitting at sss or on the docks in japan. Went well until the standard gearbox gave way. Way 2 much power 4 a vl box 2 handle. Then lost interest in the vl and decided to buy a stagea instead. AWD rocks
well what do you call it then??? cause its a rebuild he had to put new parts in it even if it isnt forgies and all that its still a rebuild at the end of the day
I would refer to it as a "freshen up" as per my previous post.
Either way it's better than a 120,000km old RB25 with 120psi across all cylinders.
    • Just as long as it's not those putridly disappointing RE003s.
    • I had this same experience going from a set of no name tyres that were on a set of good wheels (Enkei RPFs) to some Potenza RE-11s (this was a few years ago). The wet grip in particular was so much higher that it was almost scary considering how dangerous the old tyres were in comparison. The expense of the tyres also made me want them to last longer so drove accordingly. Wife happy. So now she only 'lets' me buy some flavour of Brigestones...
    • This. All of this. I am turning >$300 into small particles inside 20k km, because I like to be able to roll around any 90° street corner at the speed limit. Would my car be more fun with cheaper tyres? Possibly. When I swapped out the bald AD09s for new ones, the change in the car was massive. The obvious one was being able to put the power down instead of lighting up into silly wheelspin. But the corollary of that was that the lateral traction went from being fun to fast. It was more fun when it was loose. But the corollary to the corollary is that if I need to dodge a child in the road or emergency brake to avoid the arsehat who has just tipped a GWM on its side in front of me, then I've got a much better chance of that manoeuvre coming off without unintended "fun" meaning that I hit something else, or the original target.
    • Every time I have to buy new tyres I question what actual difference it makes between running $40 tyres and $300 tyres and whether it's worth it. Because that's a massive difference to the wallet. But then I did go to a driving training at some point which also included emergency braking and swerving in the wet. In part I think it was meant to show people how bad it gets. Funnily enough what I took away from it is that I can go much harder than I thought in my car. I presume mostly because of decent tyres. Some of the other cars there were shocking to behold. And a bit scary that cheap tyres are probably a lot more common on the road than decent ones
    • I'm pretty sure that is just straight AI generated word soup, where did you receive that ad (facebook)? They misspell Pirelli twice, no human eyes looked at that before it was posted. Incidentally, I am running the chinese pirellis on my V37 and they are.....OK....I didn't go looking for them, they were just what the shop had in stock in the tall size that car needs. LIke any brand, you really can't trust the brand's reputation to apply to every product they produce. Pirelli make good and crap tyres, all with the same logo stamped on them, and all with an attempt at price premium due to the brand
