Hey guys,
Just after some sizes and prices for tyres to fit 18x9.5 wheels. I can't seem to find an average price; the lowest I've seen is $200 and the highest is $850 :D so I'd like to get a more definite price from someone who knows what they're talking about lol
I'd like something that matches the diameter of 235/45ZR17 since that's what I already have on my car. I did a bit of research and I think I'd be looking 265/35 or something similar, but I wouldn't really know..
Anyway, if they're too expensive, I'll just get the wheels I want in 17x9, but I can't really justify paying $2000 for 17s when I know 18s would look so much better :)
Edit: I'm looking at getting Gram Lights or Drifteks. Gram Lights in silver or Drifteks in gold. Thoughts?
Edited by jimnastic
https://www.sau.com.au/forums/topic/223690-18x95-tyres/
If you're in Sydney, go to Tempe Tyres and get some Kumho KU31s. I got mine from there and I'd recommend the tyres and the dealer. They're pretty no nonsense and not all staff there are super friendly but they're good at what they do.
I got 255/35/18 on my 18x9.5s on the back for $190 each including fitting and balancing. Then 225/40/18 for the 18x8.5 on the front for $150 fitted. Good prices.
https://www.sau.com.au/forums/topic/223690-18x95-tyres/#findComment-3959074
if your looking to match up the 235/45/17, 265/35/18 is perfect rolling diameter, if you want something a bit cheaper you can go 255/35/18 which is ok, just stay away from gutters!
I have some specials on these sizes you might be interestd in, check out my thread
taleb tyre thread
https://www.sau.com.au/forums/topic/223690-18x95-tyres/#findComment-3959817
Thanks to everyone for all the helpful info :) I guess I'll probably go for 265/35/18 since they're the perfect diameter to replace my wheels
R33AzzA, Are those wheels on a GTS or a GTR? If its a GTS, what offset are they? And did you have to make any modifications to the car to make them fit?
https://www.sau.com.au/forums/topic/223690-18x95-tyres/#findComment-3972011
You're thinking of getting Gram Lights or Dickteks? A decent quality Japanese wheel compared to cheap Chinese shit that every wog and his dog has?
Get the Gram Lights, look way better but get them in 18", in that chart you linked in your first post the 17's come in no decent offsets...
https://www.sau.com.au/forums/topic/223690-18x95-tyres/#findComment-3974668
The main reason I'm looking at the Drifteks is because I can get 18x9.5 +35 with a 4 stud pattern. The biggest I can get with the Grams is 18x8 +40, which will probably look like crap, so if I get the Grams, I'll probably get them in 17x9 +35
https://www.sau.com.au/forums/topic/223690-18x95-tyres/#findComment-3978516
    • If that's the wiring from the factory, I'd be inspecting the loom everywhere.   Any signs of that anywhere else, and seriously, I'd get rid of the car ASAP before the electrical gremlins make it worthless, or it goes up in flames on its own. That is scary how that insulation is failing!
    • I should note too as I have all 4 wheel speed inputs to the emtron I now have the emtron controlling the attessa solenoid for 4wd/traction and launch control strategies.
    • It works quite well with the adjustibility within each of the programs of the turbolamik. Essentially p1 is drive and lockup comes on like a normal driver.  But in program 7 I have customised it to not request the lockup clutch to engage until something like 6500/7 when slip was the lowest.
    • Yep, I like that. The tags are only on the first post of a thread and we don't get huge numbers of new threads. Also, I plan to add some more report types and we could have a member report type like 'review tags' then members could flag if they thought a topic wasn't tagged correctly.  No way man, I dig the input. Thanks!
    • It's a valid thought. There's not exactly that functionality already (when creating a thread) - that's where the OP can use/create any tag they want. We'd have to come up with a way for the user to request their tags get reviewed or something. Otherwise the mods would have to review every new post's tags (for those that have them, anyway). There's kind of that functionality already exists to some extent, post facto of starting the thread, where the OP or any other user could report the post to admins, and request that tags get reviewed. We could do this already, and any user could already have made such a request. To make it a part of the forum proper, it would require an initial and an ongoing education programme, so that people know that it's a thing. OP based tagging/request for review would also require at least some (probably most) of the user base to be told that it's a thing they can do. Both of these things probably wouldn't spread too far and/or get used very much. If it was the standard approach on a lot of different sites, then it might do, because people would be used to it. Prank's approach to this differs from my original thought, by leaning into tagging. Which is fine - it's possibly better than what I originally suggested. In fact, I just went to the R32 GTR wiring diagram thread and added tags, including "Library". That's probably a good way to use tags and the idea of a library. We just have to drag together an (organised!) index of threads or posts that have that tag. I have yet to do any of my own follow up by pursuing worthy threads and posts and reporting/marking/tagging them for the library, such as the @Sydneykid stuff I was talking about, and possibly any amount of @Lithium 's and others' posts. At least if I tag them Library, we'll have a start.   Back to @Wazmond's idea as it relates to @PranK's, we might have some sort of a list of tags that are already used to scrape for this library. I'm not entirely sure how that would be presented or used, particularly if it got long. But it's yet another idea!   cheers
