I have searched the entire forum before asking this, aswell as UK skyline forum.
My new nismo meter set won't read speed correctly ( ie shows im doing 120kph when im actually doing 50 kph etc ) and HICAS light stays on.
I have done the following so far to fix these problems :
1. Fit a brand new speedo cable.
2. Checked oil levels for HICAS
3. Changed over speed sensor as the back of dash for orig cluster that was working fine.
4. Checked Battery power level, which is a dry cell optima yellow top with plenty of juice left in it.
The nismo set is meant to be plug and play.... Don't or shouldn't need calibration or a addon gear reduction box etc.......
Also speed reads correctly via Apexi power FC hand controller LCD display .......
are there any skyline guru's out there that could possibly shed light on this situation.......... or offer a solution.
I won't take it to nissan for them to charge me countless hours for them to try and find the problem and come to the same point as me nor a exclusive over priced performance shop that I will shell out
$'s for them to try and find problem with no solution.
any help would be greatly appreciated.
Rob
https://www.sau.com.au/forums/topic/223752-anyone-know-a-fix-for-this/
I vaguely remember someone saying early GTRs were different to latter ones in regards to the speedo, I remember someone selling one for this reason.
I think we can safely assume HICAS is acting up due to it not getting a speed signal(it relies on speed sensor used for dash)
I had a quick search, but couldn't find the thread, but im sure there was a solution for this already...
+1 for later 32's being different. When I got my 260kph dash I had to make sure it was series 1.
It is odd however that the PFC reads the correct speed.. 32's get the electronic signal from the dash so logic would dictate that if that isn't reading correctly then the ECU shouldn't be either..
If the PFC is getting the correct speed then I think HICAS should be too. Did you have your steering wheel off at all?
The speed sensor is the only change between the early models up to the 91/8 series.
The speed sensor and speedo is excatley the same as my current GTR speedo, I even swapped the speed sensors to double check.
Also the apexi PFC displays the correct speed which relies on the data front he speed sensor, hence I hence rule that out.
The HICAS light is on but I have full steering.
I have never had the steering wheel off.
and the extra confuse the FUBAR`D situation the speedo worked correctly once.....
the only thing I can think of is the little square slot in the back of the speedo is slightly worn and not making proper contact..... thats a very long stretch though.
I have been through all the normal causes for this problem.
Must be someone out there taht can shed some light on this....
  bubba said:
Even if the slot was worn the ECU's are still getting the speed signal after the cable goes into the speedo.. I'd be looking more at the speedo itself and 70kph difference is a lot!
the speed sensor is working correctly.
the nismo dash has gearing down already, its a plug n play item. But to me its a plug and cluster f**k.
If the speed sensor is all good, then all it can be is the mechanicals in the the speedo itself.. stands to reason.
Do you still have the original one to plug back in and try?
Can't see any reason for it to do that sort of silliness unless the meter itself is shot. Pull it out of the cluster (just a couple of crews) and have a look.
edit* the difference between early and late dashes is the pinouts and layout of the back of the cluster, and the mountings and design of the speed sensor on the back of the speedo. I had to modify mine as it came with a late model dash that had been dropped in, and the monkeys had left it all borked. Not too hard to do, if you have the original dash there to compare with.
Edited by heller44
ive got the same issues mines a 1993 my speedo is constantly out(stock) sometimes double what its meant to be. my hicas light is constantly on except for those few times where it briefly blinks off
Have you had any solutions yet?
Have you guys considered using a speedo correction kit, like Jaycar sells?
I know its not an ideal solution to the problem, but it should work.
Another thing just popped into my mind, are the senders from the gear box the same thru out the R32 GTR range?
This could also be causing issues?
tristran, that won't work. The r32 speedo is mechanical, from the gearbox right to the instrument cluster.
So.. if the speed signal on the pfc is good, that means that the drive up to the back of the cluster is good, so all it leaves is the mechanical bit after the initial joint where the cable mates.
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
