I have searched the entire forum before asking this, aswell as UK skyline forum.
My new nismo meter set won't read speed correctly ( ie shows im doing 120kph when im actually doing 50 kph etc ) and HICAS light stays on.
I have done the following so far to fix these problems :
1. Fit a brand new speedo cable.
2. Checked oil levels for HICAS
3. Changed over speed sensor as the back of dash for orig cluster that was working fine.
4. Checked Battery power level, which is a dry cell optima yellow top with plenty of juice left in it.
The nismo set is meant to be plug and play.... Don't or shouldn't need calibration or a addon gear reduction box etc.......
Also speed reads correctly via Apexi power FC hand controller LCD display .......
are there any skyline guru's out there that could possibly shed light on this situation.......... or offer a solution.
I won't take it to nissan for them to charge me countless hours for them to try and find the problem and come to the same point as me nor a exclusive over priced performance shop that I will shell out
$'s for them to try and find problem with no solution.
any help would be greatly appreciated.
Rob
https://www.sau.com.au/forums/topic/223754-anyone-know-a-fix-for-this/
No speed means your HICAS mucks up fix speedo and all will be good.
Edit. opps sould have read the hole lot frist. When my speedo didnt work at all i had HICAS problems maybe yours is reading that the car is always moving so it has no idea whats happening.
what would cause that?
also can't be speed sensor becuase apexi power FC hand display ready correctly... which gets it information from the speed sensor right....
Also power steering is still 100%....
there must be one person out there with a solution..... seriously.
while i was searching for an answer to your problem it occuored to me that the magnets on the needle of the cluster still use 12 volts, regardless of whether it is a standard skyline cluster or not,
which means that a standard speedo drive would under drive the needle giving the incorrect speed, also hence why the hicus is having issues because the speed is saying one thing yet the sensors at each hub are giving conflicting information.
the reason i say this the early nismo gtr's had 260kph speedo's not 320kph like the later gtr's, mines a november 92 gtr and has 260 on the clock. i suspect the speedo cluster you have there is for the v spec model.
the speed sensor at the dash is moved within the speedo itself and then sends electrical pules that hen allow the ecu to kow the speed, hence the fc handheld LCD is showing correct speed.
I checked with nissan dealer about the part number, which they said was for a 1990 r32 GTR......
aftermarket nismo speedos are pretty standard for GTRs and the like.
I already have a aftermarket 260km/h nismo black dash that works perfect on my R32 GTR.
any other suggestions....
There should be two speed sensors - one is part of the cluster the other is part of the gearbox...Find out which one your (working) Power FC is connected to (i.e. gearbox speed wire or dash speed wire) and then you will know which one is playing up.
nah, 32's only have the one, at the cluster. they have a cable driven speedo.
Thats what I thought.
I'am just at that point of I don't know what to do. It works somtimes and I have replaced the cable.... and the apexi handset reads true... so the speed sensor is fine.
what else could cause this?
there must be someone in Australia with an idea.
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
